Register to reply
Apparent Magnitude
by devd
Tags: apparent magnitude
Share this thread:
devd
#1
May20-14, 05:10 PM
P: 15
What does this statement mean: "Apparent magnitude of a star, X, is m." ?
[itex] m_2 - m_1 = -2.5 log (B_2/B_1) [/itex]
Apparent magnitudes are defined relatively, right? We can talk about differences in apparent magnitudes. If i know the ratio of the brightnesses, i can find out the difference in apparent magnitudes. Do we have some kind of reference magnitude, relative to which we can make the statement in quotes?
Phys.Org News Partner Astronomy news on Phys.org
Comet Jacques makes a 'questionable' appearance
Image: Our flocculent neighbour, the spiral galaxy M33
Image: Chandra's view of the Tycho Supernova remnant
jedishrfu
#2
May20-14, 05:14 PM
P: 2,794
Apparent magnitude is related to what we see as we compare star brightness. As an example, we see the sun as the brightest star in the sky but all other naked eye visible stars are much brighter than our sun.
http://en.wikipedia.org/wiki/Apparent_magnitude
devd
#3
May20-14, 05:58 PM
P: 15
I can understand that qualitatively. But, what about the quantitative statement?
phyzguy
#4
May20-14, 07:01 PM
P: 2,179
Apparent Magnitude
Quote Quote by devd View Post
Your quantitative expression is correct, and it is true that you need some reference to set the scale. Historically the star Vega was assigned an apparent magnitude of 0.0 to set the zero point of the scale. However, today the reference is defined as a certain flux in ergs/s/cm^2/Hz, as shown in the table in the Wikipedia entry. Vega is still quite close to an apparent magnitude of 0.0 with this definition.
jedishrfu's statement is incorrect. Apparent magnitude describes how bright an object appears. No celestial object has an apparent magnitude brighter than the sun (obviously). I think what jedishrfu was trying to say refers to absolute magnitude, which describes the intrinsic brightness of an object. Absolute magnitude is defined as the apparent magnitude of the object when viewed at a distance of 10 parsecs. The sun has an apparent magnitude of about -27, but an absolute magnitude of +4.83, so it would be a dim naked eye star if it were 10 parsecs away. While it is true that most naked-eye stars are intrinsically brighter than the sun (meaning they have an absolute magnitude less than the sun), it is not true that all naked eye stars are intrinsically brighter than the sun. Epsilon Eridani, for example, is a nearby naked eye star with an apparent magnitude of +3.7 but an absolute magnitude of +6.19, meaning that it is intrinsically fainter than the sun
abitslow
#5
May21-14, 02:35 PM
P: 140
Its one of the many ironies of Science that the thing that is easy to measure (brightness) is not considered absolute, and that absolute magnitude is a calculated (adjusted) value which requires several estimated parameters to determine (even apparent magnitude does). I expect I'm not telling you anything if I rearrange your equation to:
m' = m-2.5*log(B'/B) [where m'=m_sub2, B'=B_sub2, m=m_sub1, etc.] which answers your question (as long as we agree what (star) to use for m and B (as well as units and measurement). No particularily good reason that brightness should arbitrarily use the visible spectrum, other than that's what we see. Why its adjusted to remove atmospheric filtering is another question. Between any star and us is the following filters: dust and gas and plasma, the atmosphere of the Earth, the optical properties of the telescope, the optical clarity of our eyes, the sensitivity of your eye to different wavelengths (there are as many 'average' observers as there are 'average families'(with 2.1 children)). Its a very good idea to specify a (range of) wavelengths (as well as how the cut-off at each end is handled), but its not been that long since we first figured out how to measure the flux at a given wavelength with high accuracy. Early photodetectors were notoriously inefficient at capturing photons.
Register to reply
Related Discussions
Apparent magnitude Astronomy & Astrophysics 1
Combined apparent magnitude Advanced Physics Homework 1
Calculating absolute magnitude and apparent magnitude Advanced Physics Homework 1
Apparent Magnitude Astronomy & Astrophysics 3
Apparent magnitude Introductory Physics Homework 1
