What should be the particular solution?
- Context: Undergrad
- Thread starter tony_engin
- Start date
- Tags
- Particular solution
The discussion revolves around determining the appropriate form of a particular solution for a specific differential equation. Participants explore various methods for finding this solution, including trial functions and the method of variation of constants, while addressing the nuances of the problem.
- Technical explanation
- Debate/contested
- Mathematical reasoning
- One participant suggests trying the form "[Asinx + Bcosx + C] exp(-2x)" for the particular solution.
- Another participant agrees that this form is acceptable.
- Some participants propose using the method of variation of constants as an elegant alternative.
- A different proposed form is "x^{2}e^{-2x}(Ax \cos 2x + Bx \sin 2x + C)", introducing additional complexity.
- One participant indicates that the correct form should be "[1+xcosx] exp(-2x)", challenging the initial suggestion.
- There is a discussion about needing to include an "x" in the trial function due to the presence of the exponential in both the homogeneous solution and the nonhomogeneous term.
- Clarifications are made about the necessity of omitting certain terms, such as the constant "C", from the trial function.
- Another participant outlines a method involving differential operators to eliminate the right-hand side of the equation, leading to a more complex solution structure.
- Further calculations and substitutions are discussed, leading to a derived particular solution and a general solution, with an emphasis on the process rather than the final result.
Participants express differing opinions on the correct form of the particular solution, with no consensus reached. Some support the initial trial function while others argue for alternatives, indicating an ongoing debate.
Participants reference various methods and forms for the particular solution, but the discussion remains open-ended with unresolved mathematical steps and assumptions about the differential equation's structure.
Undergrad
General solution vs particular solution
- · Replies 52 ·
- · Replies 5 ·
- · Replies 2 ·
- · Replies 5 ·
- · Replies 3 ·
- · Replies 4 ·
- · Replies 2 ·
Undergrad
Assumptions about particular solutions
- · Replies 3 ·
- · Replies 5 ·
