How Do You Find the Gradient of a Line?
  • Thread starter Thread starter SleSSi
The discussion revolves around finding the gradient of the line represented by the equation y - 3x = 2. Participants explore the concept of gradient in the context of linear equations and its relation to slope.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss converting the equation into the form y = mx + c to identify the gradient. Questions arise about the relationship between slope and gradient, as well as the implications of different types of lines, such as vertical lines.
Some participants provide insights into the definition of gradient and its calculation, while others express confusion regarding the terminology and its application in different contexts. There is an ongoing exploration of the implications of vertical lines and the concept of undefined gradients.
There is mention of potential confusion arising from discussing gradients in relation to vector fields and derivatives, which may detract from the original question about linear functions.
SleSSi
i need to find the gradient of the line y-3x=2 how do i do it again?
Put it in the form y = mx + c and m is the gradient.
What's the connection between the slope of the line & its gradient...?
Daniel.
hey,
{y-displacement}/{x-displacement} = gradient displacement is how much y changes and x changes from two points.
The gradient IS the slope of the line
Regards,
Ben
Rise over Run - is how I remember it.
Wait, is this gradient the same gradient as in gradient of a vector field or does it mean gradient like slope of the line?
Slope of line - y=mx +c
Regards,
Ben
The original question was about y- 3x= 2, a real valued linear function of a single real variable. I'm afraid all that talk about "vectors" and even "derivatives" will just confuse the original poster.
Slessi: solve for y. In this example, solving for y gives y= 3x+ 2 so the gradient (slope) is 3. (Almost) any linear equation can be solved for y in the form y= mx+ b and the gradient is the number m.
(I say "(Almost)" because a vertical straight line, like x= 1, cannot be put in that form: it has NO gradient.
I was just staring at this statement whilst drinking tea and began to think, there is a gradient because gradient is [y-displacement]/[x-displacement] and in this case, 0/change in x. Change in x is always a non-zero integer value and therefore the gradient is 0/non-zero integer = 0. Looking at the graph, this fits, the gradient looks to be 0.
However, if the graph is of y=1 ,then the equation becomes: [change in y]/0. Change in y is always a non-zero integer value and therefore the gradient is non-zero integer/0 which is mathematically undefined. However, if one looks at the graph in a topolgical sense (Pemrose is my source on the idea of topolgy), then the gradient looks to be -infinity or +infinity. And this leads one to consider what result dividing by 0 gives.
Anyway, those are just my thoughts,
Regards,
Ben
Yes, that's exactly right.
No, that's exactly wrong. The equation in question is x= 1. x is always 1: x doesn't change, y can be anything: the equation is change in y/0.
Where in the world did you get that idea? If x= 1 the change is 0! x= 1 means exactly that: x is always 1, not the "change" in x!
Same error: if y= 1 then y does not chage: the slope is 0/change in x= 0.
Hi, I commented on x=1 instead of y=1 and visa versa - please reread the post in its now corrected form (below) and give your throughts.
I was just staring at this statement whilst drinking tea and began to think, there is a gradient because gradient is [y-displacement]/[x-displacement] and in the case of y=1, 0/change in x. Change in x is always a non-zero integer value and therefore the gradient is 0/non-zero integer = 0. Looking at the graph, this fits, the gradient looks to be 0.
However, if the graph is of x=1 ,then the equation becomes: [change in y]/0. Change in y is always a non-zero integer value and therefore the gradient is non-zero integer/0 which is mathematically undefined. However, if one looks at the graph in a topolgical sense (Pemrose is my source on the idea of topolgy), then the gradient looks to be -infinity or +infinity. And this leads one to consider what result dividing by 0 gives.
-Ben
  • · Replies 19 ·
