Interesting Physics Project: Slingshot car
The discussion centers on constructing a manpowered cart designed to launch a volleyball 8-10 meters using a slingshot mechanism. The cart dimensions are specified as approximately 5'3" in length, accommodating one person. Key insights include the optimal slingshot angle of 45 degrees for maximum range, although the fastest ball speed is crucial for delivering force to the target. Surgical tubing is recommended as a suitable material for the slingshot, with suggestions to stabilize the ball using four lengths attached to the pouch.
  • Understanding of basic physics principles, particularly projectile motion
  • Familiarity with materials such as surgical tubing and their applications
  • Knowledge of cart design and stability considerations
  • Experience with angle optimization in launching mechanisms
  • Research the properties and vendors of surgical tubing for slingshot construction
  • Explore projectile motion equations to calculate optimal launch angles and velocities
  • Investigate different materials for cart construction to enhance stability and performance
  • Learn about the mechanics of slingshot design and how to maximize force delivery
This discussion is beneficial for physics students, hobbyists in mechanical engineering, and anyone interested in designing and building projectile-launching devices.
jen333
Hey,
for a physics project, i have the task of building a manpowered cart that will fit one person in and slingshoot a regular volleyball a whopping 8-10m! the basic plan so far is to have the cart approximately 5'3 in length and just wide enough to fit the person it. The task is to hit a target composed of a pile of buckets that need to be knocked down. it's been found that in order to have the most powerful force, the slingshot must be positioned at forty five degrees. any ideas on what material could be used to make the slingshot, or how? ideas appreciated!
:biggrin:
You asked for ideas...here's one : http://www.globalspec.com/trebuchet/
jen333 said:
Hey,
:biggrin:
If you cannot get hold of one of those other suggested contraptions :smile: you might get some surgical tubing for your slingshot. Just put "surgical tubing" into google, and you will find vendors. The first one I found was advertising it for use as "spear gun tubing". You will probably want 4 lengths of it to attach to the corners of the "pouch" to stabilize the ball.
The 45 degrees will give you the longest range, but that does not mean the most powerful force on the target. The most force will be from the fastest ball that can reach the target. Some elevation will be wanted, but I expect you can do with less than 45 degrees.
17K
