A few questions in relation to energy
  • Thread starter Thread starter lektor
    Energy Relation
This discussion addresses key concepts in physics related to collisions, impulse, and orbital mechanics. It confirms that in elastic collisions, two objects do not always move off at right angles, as momentum and kinetic energy conservation allow for various outcomes. It clarifies that an object can receive an impulse without work being done if there is no displacement, and conversely, work can be done without an impulse if the force is perpendicular to the direction of motion. Lastly, it explains that a satellite increases its speed when losing energy due to gravitational potential energy conversion into kinetic energy as it descends into a denser atmosphere.
  • Understanding of elastic collisions and conservation laws
  • Knowledge of impulse and work-energy principles
  • Familiarity with orbital mechanics and gravitational potential energy
  • Basic proficiency in vector analysis and Pythagorean theorem
  • Study the principles of elastic and inelastic collisions in detail
  • Learn about impulse-momentum theorem and its applications
  • Explore gravitational potential energy and its relationship with kinetic energy in orbital mechanics
  • Investigate the effects of atmospheric drag on satellite motion and energy conservation
Students and professionals in physics, aerospace engineering, and anyone interested in understanding the dynamics of motion, energy conservation, and satellite mechanics.
lektor
we were assigned a few to find answers to, the following ones stumped me, hopefully you can help :)
When two objects of different masses collide and the collision is elastic, it is said that the two objects will always move off at right angles to each other.
Is this likely to be true? Explain
Can an object, perhaps in motion, receive an impulse without having work done on it?
Conversely, can an object have work done on it without receiving an impulse?
3) If a satellite in circular orbit around the Earth encounters the outer fringes of the atomosphere, it begins to lose energy through friction. Yet the result is that it increases speed, Why is this?
idea for 3) Is this because it Moves closer to the Earth and has a greater force of gravity acting upon it
1) It is not necessary that the balls always travel prependicularly to each other after collision.In elastic collision both momentum and kinetic energy is conserved and there is no energy loss through heat or sound.Both the cases are possible.
2)Impulse is basically Force/second. So if the force is applied for a short time in a such a way that no displacement occurs,no work is done by the impulse.Example, drop a ball over a block kept on a smooth surface.
3) Orbital velocity of a satellite in arbit of radius "r" from the centre of the Earth is given by:
[itex] \sqrt{\frac{GM}{r}}[/itex]
As r decreases, its orbital velocity decreases and it loses energy.By losing energy, it does not mean it loses its kinetic energy.Net energy of a satellite in its orbit is given by:
[itex] \frac{-GMm}{r}[/itex]
Therefore as r decreases ,its energy decreases due to the minus sign.As the above energy is the sum of [Kinetic Energy+ Potential Energy] Therefore ,as its orbital velocity increases when it loses some potential Energy.
Therefore,
THE SATELLITE GAINS KINETIC ENERGY ON ACCOUNT OF LOSING POTENTIAL ENERGY WHEN IT COMES NEAR TO EARTH.
Yes. If you play pool, it is very useful because it allows you to play 'shape'. Otherwise you will not be able to predict where the cue ball goes.
Since [itex]\vec v_1 + \vec v_2 = \vec v_0[/itex] (momentum conserved) and [itex]v_0^2 = v_1^2 + v_2^2[/itex] (energy conserved) the vector diagram of the collision defines a triangle in which v0 is the hypotenuse whose length is related to the sides by the pythagorean formula. This means the angle between v1 and v2 is a right angle).
If [itex]F_{net}dt = (dp/dt)dt \ne 0[/itex] then dp is nonzero. [edit:] This means that its velocity must change. But, of course, this does not necessarily its speed changes - the change could be in direction only (speed is unchanged). If the direction of the force and momentum are perpendicular to each other, there is a change of momentum but no change in speed - hence no change in energy.
It increases vertical speed as it loses its tangential speed. This is because as it slows its orbital speed it falls toward the Earth and thus loses gravitational potential energy. This loss of potential results in an increase in kinetic energy (ie energy is conserved).
AM
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 67 ·
