Calculating Incline Distance for a Rolling Sphere | Review Questions Answered
  • Thread starter Thread starter cde42003
    Review
The discussion revolves around two physics problems: one involving a hollow sphere rolling up an incline and the other concerning the oscillation frequency of a two-block system suspended from a spring. Participants express uncertainty about the methods to derive the answers and seek clarification on the underlying principles.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the application of conservation of mechanical energy for the rolling sphere problem and question the role of friction. They explore the relationship between kinetic and potential energy, considering the contributions of rotational motion.
  • For the spring problem, there is confusion regarding the calculation of the spring constant and how to relate it to the oscillation frequency. Participants question the assumptions made about the system and the information provided.
Some participants have made progress in understanding the first problem, identifying the need to relate height to the incline angle. However, there is still a lack of consensus on the second problem, with ongoing inquiries about how to derive the spring constant and frequency from the given data.
Participants note the absence of specific mass values for the blocks in the spring problem, which complicates the calculations. There is also mention of homework constraints that may limit the information available for solving the problems.
cde42003
Review Questions- Need Help!
A hollow sphere is rolling along a horizontal floor at 5.00 m/s when it comes to a 30.0° incline.
How far up the incline does it roll before reversing direction?
I am not sure how to start this problem. I know the answer is 4.25m but do not know/understand how that answer was derived.
A block hangs in equilibrium from a vertical spring. When a second identical block is added, the original block sags by 6.00 cm.
What is the oscillation frequency of the two-block system?
Here I thought you could say that the 6 cm was the amplitude and derive the answer from that, but my answer was incorrect. I don't know where to go with that not working.
Thanks for the help
For the first question, I'm assuming friction is not a consideration. In that case, use conservation of mechanical energy.
Thanks for the help
The energy hint from cepheid is the way you want to go on the first one. Just remember that rolling balls, disks, logs, etc have two contributions to their kinetic energies.
For the second problem, the information given is sufficient to find the spring constant. It is important to note that the block being added is identical to the one that was already hanging.
On the first one I have tried the mechanical energy and have come up empty.
Here is my work:
1. .5mv^2 + .5*I*omega^2 = mgh
2. I then substituted for I and omega to get:
3. .5mv^2 + 1/3mv^2 = mgh
4. h= (.8333*v^2)/g
I get an answer of 2.125. Can you see where I went wrong? Thanks
On the second one can you give me a little more detail on how to find the spring constant? I can see trying to use the potential energy, but do not know where to get the necessary information.
what is the inertia of a hollow sphere? [itex]I=\frac{2}{3}mr^2[/itex]?
hmmm, let's see:
[tex]\frac{1}{2}mv^2+\frac{1}{2}I\omega^2=mgh[/tex]
[tex]\frac{1}{2}mv^2+\frac{1}{2}(\frac{2}{3}mr^2\frac{v^2}{r^2})=mgh[/tex]
[tex]\frac{1}{2}mv^2+\frac{1}{3}mv^2=mgh[/tex]
[tex]3mv^2+2mv^2=6mgh[/tex]
[tex]5v^2=6gh[/tex]
[tex]\frac{5v^2}{6g}=h[/tex]
[tex]h=2.125~meters[/tex]
yea, i got the same thing as cde42003. :confused:
You're both correct. You haven't completed the problem yet though.
Hint: The question is, how far up the ramp will the ball go?
I have figured the first one out now. You had to take the value of h and divide by
sin(30°) to get the answer.
Can anyone help me on the second question?
Thanks
Thanks
I did in #3 :smile:
How can you find the spring constant from the information given, and how do you use it to find the frequency?
OlderDan said:
I did in #3 :smile:
I am trying to follow you but I cannot think of how to find the spring constant from the given info. I do know how to find the frequency from the spring constant but I cannot get this far. What equation do I need to use for the spring constant? Thanks and I am not trying to get off without doing any work, I am just trying to figure this out before my exam tomorrow.
Hooke's Law tells you that a spring stretches an amount that is proportional to the force applied. With one mass hanging on the spring, it is stretched by an unspecified amount, but when the second mass is added, it stretches another 6 cm. Any additional force added to a spring stretches it an additional distance dtermined by the same constant. In other words, if
[tex]F = -kx[/tex]
then
[tex]\Delta F = -k\Delta x[/tex]
You can determine the spring constant from the additional stretching that results from the additional force. You have the total mass of the system after the second one is added, so now you have all you need.
Good luck on your exam.
[tex]F = -kx[/tex]
then
Ok. So since the the change in force is proportional to the change in x:
.06N = -k(.06 m)
When I tried it this way, I got the answer to be 2.03 Hz which was incorrect. What Am I still not getting?
.06N = -k(.06 m)
WAIT! You can do this!
All you need is the ratio of the mass to the spring constant
[tex]\Delta F = (\Delta m)g = k\Delta x[/tex]
Doubling the mass is going to double the stretch so you have
[tex]2mg = k (2X_s)[/tex]
where m is the mass of each of the two masses, and [itex]X_s[/itex] is the stretch from the one mass, or 6 cm. Note that this [itex]X_s[/itex] is not the position of the mass at any particular time during oscillation. It is the amount that one mass stretches the spring when the mass is at equilibrium hanging on the spring.
[tex]\frac{k}{2m} = \frac{g}{2X_s}[/tex]
[tex]f = \frac{1}{2\pi}\sqrt{\frac{k}{2m}} = \frac{1}{2\pi}\sqrt{\frac{g}{2X_s}} = \frac{1}{2\pi}\sqrt{\frac{9.8}{.12}} Hz[/tex]
OlderDan said:
OOPs! Sorry. I had it in my mind that you had been given the mass of the first block. Now I look back and I don't see it. If you don't know the mass of the blocks, you cannot do this problem. Check the problem again and see if there is some other information you did not include.
There really is no other information. That is why I was stuck. I can't see anyway to do the problem. Thanks for the help
I was wrong about this. Take another look at my previous post.
  • · Replies 17 ·
