Register to reply
Stream function along solid boundary
by TomBolton10
Tags: boundary, function, solid, stream
Share this thread:
TomBolton10
#1
Jun5-14, 08:14 AM
P: 1
Hi, I am studying fluid mechanics and I am trying to get to grips with slip and no-slip boundaries.
I know that:
Slip ---> Occurs when fluid is inviscid so no viscous stress at boundary.
No-slip ---> Viscous effects mean the the tangential velocity must be zero, relative to the boundary.
Also, for both slip and no-slip boundary conditions you have no normal flow if the boundary is solid and impermeable.
However, the problem I have is that some say that if you have the no normal flow condition, then the stream function is constant regardless of whether it is a slip/no-slip boundary (http://scicomp.stackexchange.com/que...ream-functions). My lecturer however said that the stream function is constant only when it is a slip boundary. Any thoughts? Who is correct?
Phys.Org News Partner Engineering news on Phys.org
Student develops filter for clean water around the world
Developing the next evolution in underwater communication
Compact vibration harvester power supply with highest efficiency opens door to "fix-and-forget" sensor nodes
Chestermiller
#2
Jun5-14, 10:14 PM
Sci Advisor
HW Helper
Thanks ∞
PF Gold
Chestermiller's Avatar
P: 5,043
Quote Quote by TomBolton10 View Post
I know that:
Your lecturer is wrong, and what "some say" is correct. Just look at the relationship between stream function and velocity to see this. unormal=-∂ψ/∂x, where x is the coordinate along the wall.
Look up in the literature the solutions for inviscid- and viscous flow past a sphere. In both cases, the stream function is constant on the sphere.
Chet
Register to reply
Related Discussions
How to calculate the stream function from the potential function? Classical Physics 0
Stream function Classical Physics 1
Why must stream function be 2d? Classical Physics 1
Stream Function in 3D Classical Physics 0
Stream Function Calculus & Beyond Homework 1
