Measuring CO2 Useage on Moving Objects
In summary, the conversation discusses different ways to measure the amount of CO2 left in a cylinder mounted on a moving object. These include using load cells, a thermal mass-flow meter, an asymmetric beam balance, and techniques such as ultrasonic pulse reflectance and heating the cylinder wall. The conversation also mentions potential challenges and safety concerns with these methods and suggests looking into alternative gases.
blkexp98
I have a project that I have been thinking about and need to us CO2 for it. What ways are there to measure the amount of CO2 left in a cylinder if its mounted to a moving object? I thought about the normal scale method but with bumps it wouldn't be accurate. You can't really measure pressure since it self regulates in a way and will change with temperature. The only other thing I have been able to come up with is measure the flow and come up with a calculation that a certain volume weighs so much but that seems like that would leave a pretty high margin of error. The only way I see to get close using that method is to fill your own tank that you know the weight on with a known weight of liquid CO2 using a scale.
You have not specified the rate of CO2 use, is it kg per minute or ug per hour.
(1). Weigh the tank on load-cells but have another load-cell, with a smaller reference mass, to identify when there is no bump, or to generate a mass ratio. For times when there are too many bumps you measure the P, V and T of the CO2 being used. Subtract that from the last known good weight. A thermal mass-flow meter would be able to estimate usage.
(2). Use a load cell, but record the data continuously. The long term average represents the mass. By picking an optimum time period for the running average, the major component of vibration could be reduced.
(3). Weigh the tank on an asymmetric beam balance. A movable fulcrum mounted on a rubber block.
(4). Sense the presence of liquid level in the cylinder by looking at the reflectance of an ultrasonic pulse from outside the cylinder wall. A similar technique as is used for measuring the thickness of steel plate.
(5). Measure the level in a cylinder by momentarily heating the CO2 cylinder wall. The wall will cool more rapidly adjacent to the liquid, more slowly where there is gas. Campers pour a little hot water down the side of their gas cylinders. The resulting pattern quickly identifies the level of the gas-liquid boundary.
I don't have any useage info yet. Those are some good ideas and starting points. Ill do some more research on them and see what would be the good and bad points of the methods. That may steer me in a more focused direction. 1,2 and 3 would work well in a horizontal position too where as 4 would be better in a vertical position to keep sloshing of the liquid to a minimum. Short of a custom tank I don't think they make baffled tanks since there really wouldn't be any use for them other than a very special application.
You could put something like an open cell foam or activated charcoal into your tank to stop sloshing.
I have been working on measuring volume for a while and perhaps you can build something similar. You can release part of the gas (if that's possible) by opening a valve through a flow restrictor and measure the time it takes for the Pr to drop certain amount (1% for instance). With that info you can reconstruct the exponential equation and find the gas volume in the tank. In this case (contrary to mine) temp will not be a problem, I think. The time required for the Pr to drop certain amount is independent of the temp and only depends on the volume of gas and the flow restrictor.
Problem is, you will be loosing part of the gas and being CO2, I don't know if you can do that legally and/or safely. You need to find out that first or use another gas. There are serious difficulties though in making the system work and measure time accurately.
Hope it helps.
You can check it out here:
https://www.physicsforums.com/showthread.php?t=753039
What is CO2 usage?
CO2 usage refers to the amount of carbon dioxide released into the atmosphere by a particular object or activity. It is often measured in terms of volume or weight.
Why is it important to measure CO2 usage on moving objects?
Measuring CO2 usage on moving objects is important because it allows us to understand the impact of transportation and other mobile activities on the environment. It also helps us identify areas where we can reduce our carbon footprint and mitigate the effects of climate change.
How is CO2 usage on moving objects measured?
CO2 usage on moving objects can be measured using various methods such as direct measurement with sensors, calculation based on fuel consumption, or estimation using emission factors. The most accurate method depends on the specific object being measured and the available resources.
What factors can affect CO2 usage on moving objects?
The main factors that can affect CO2 usage on moving objects include the type of fuel used, the efficiency of the engine or motor, the weight and aerodynamics of the object, and the distance traveled. Weather conditions and driving or operating habits can also have an impact.
How can we reduce CO2 usage on moving objects?
There are several ways to reduce CO2 usage on moving objects, including using alternative fuels, improving the efficiency of engines and motors, implementing more sustainable transportation methods, and changing individual driving or operating habits. Regular maintenance and proper tire inflation can also help reduce CO2 emissions.
  • Classical Physics
9K
  • Thermodynamics
  • Chemistry
  • Mechanics
