Register to reply
Thermal Compound, calculating amount of hardener and resin by weight
by 2slowtogofast
Tags: compound, hardener, resin, thermal, weight
Share this thread:
2slowtogofast
#1
Jun7-14, 10:24 AM
P: 132
I have a simple question. If when mixing two liquids together the directions say mix 10.4 parts of hardner by weight for every 100 parts of resin and I want the final mixture to be 2.75lb, could I do the following?
Mh = mass of hardener
Mr = mass of resin
Mh + Mr = 2.75lb
Mh/Mr = 10.4/100 = .104
Then just solve from there to get the amount of each. I know this should be pretty straight forward but I just wantedto double check. Thanks in advance.
Phys.Org News Partner Engineering news on Phys.org
Researchers discover cool-burning flames in space, could lead to better engines on earth (w/ Video)
Professors object to FAA restrictions on drone use
UConn makes 3-D copies of antique instrument parts
Chestermiller
#2
Jun8-14, 08:27 PM
Sci Advisor
HW Helper
Thanks
PF Gold
Chestermiller's Avatar
P: 5,055
This looks OK.
Chet
markx
#3
Jun9-14, 02:28 AM
P: 1
I always like to lay these things right out as percentages:
You need 9.42% hardener, and need 90.58% resin.
10.4/(100+10.4) = 0.0942
100/(100+10.4) = 0.9058
Mh 0.0942 x 2.75 = 0.259
Mr 0.9058 x 2.75 = 2.491
check1: 0.259 + 2.491 = 2.75
check2: 0.259/2.75 = 0.0942 = 9.42%
Register to reply
Related Discussions
Calculating compound interest Precalculus Mathematics Homework 5
A compound with a molecular weight of 110.1 g Biology, Chemistry & Other Homework 6
Electrolysis When calculating amount of charge from an amount of Chemistry 1
Heat Conductivity, Copper and Thermal Compound scenarios Introductory Physics Homework 4
Amount in mol of compound ions Biology, Chemistry & Other Homework 5
