Net force zero = velocity > zero ?
The discussion centers on the relationship between net force and velocity, specifically whether an object can have zero net force while maintaining a non-zero velocity. Participants explore the conditions under which this can occur and the implications of Newton's First Law of Motion.
  • Some participants assert that if the net force on an object is zero, the object can maintain a constant non-zero velocity, provided no external forces act on it.
  • Others emphasize that friction constitutes an external force, which complicates the scenario of having zero net force while moving.
  • A participant suggests that a spaceship accelerating and then ceasing to accelerate exemplifies a situation where net force becomes zero, yet the ship continues moving at its last speed.
  • Some participants reference Newton's First Law, indicating that an object will either remain at rest or move with constant velocity when no net force acts on it.
  • There are discussions about the difficulty of achieving a state of zero net force in practical scenarios due to forces like friction and air resistance.
  • A participant mentions using Free Body Diagrams to illustrate net forces and their components, highlighting the importance of reference frames in understanding motion.
Participants express differing views on the conditions necessary for an object to have zero net force while moving. While some agree on the theoretical basis provided by Newton's First Law, others challenge the practicality of such a scenario due to external forces like friction.
Participants note the complexities involved in real-world applications of the concept, including the influence of external forces and the assumptions required to consider net force as zero.
This discussion may be of interest to students and enthusiasts of physics, particularly those exploring classical mechanics and the principles of motion.
choggo
net force zero = velocity > zero ??
can the net force on an object be zero yet the velocity not be zero?
I say yes but under what conditions and must any restrictions be placed on the magnitude or direction of the velocity?
Yes. The condition is that there is no force applied on the object. Then the velocity will be constant which can be non-zero. Magnitude and direction do not have any restrictions (assuming that there's nothing it can collide with etc.).
You may want to reread and understand Newton's First Law, which explicitly indicates that for an object with no net force, it will either be stationary, or move with a constant velocity. This is the beginnings of the concept of no preferred inertial reference frame.
Zz.
It's the essence of the reinterpretation of the first postulate in terms of forces (defined in the second one).The principle of inertia applies,iff the vector sum of all forces acting on the body/system is zero.
Daniel.
Thank you but...how can the velocity be constant and the external force be net zero? Would not friction cause an object to slow? Would the conditions have to be in space? I am a novice so go easy. Thanks
When there's friction, there's no longer the condition where no net force is acting on the object. Friction IS a form of an external force acting on that moving object.
Zz.
if there is friction there is force. the space would have to be empty.
OK guys...give me an example where this can occur...its easy to say that the net force is zero and velocity can be something other than zero but I have not seen any examples yet.
How about a spaceship that is accelerating and then stops accelerating...the net force is removed and yet the ship will continue moving at the last speed before removal of the force...sound good?
Pretty much so.However,the principle of inertia is still valid.
Daniel.
EDIT:Yes,it does.
Basic stuff - Check out Newton's first law of Motion. You need a force to STOP a body moving, or to start it moving. You most certainly do not need a force to keep something moving. Think about the Voyager space probes for example.
Don't feel too dumb, though.
Precisely because it is very difficult to totally remove forces like friction and air resistance from acting upon an object, the "natural" idea is to assume that objects tend towards a state of rest (the Aristotelian view). The inertia concept (as developed by Galileo, and later Newton) is subtler/more difficult to understand because it seems to go counter to our day-to-day experiences.
Fnet = sum of Forces (x,y,z). I use the Free Body Diagram to illustrate Fnet and anet. The forces acting on an object are drawn on the FBD (Fgrav, Ffriction, Fapplied, Tension, Fnormal, Fair, Fspring). Then the forces are added vectorally to find the resultant or net force. I encourage my students to view anet as the acceleration that you see or feel (if you are part of the system). Reference frames, as always, are critical here.
Choggo, I guess you aren´t thinking in terms of NET force, but, instead of this, in terms of the force that YOU, as an extern agent, is applying on the object. Of course that YOU are aplying a force, you are "feeling" the force you are aplying on the object, BUT, otherwise, the 1st Law says that the NET force NEED to be zero for that the actual state of rest or uniform movement (both having a=0) remains like that. Your force on the body exists, and it will always exist in real cases because the friction, the gravity or any other sort of oposite force, but so as to know the behavior of the velocity of the body (if it´s changing or not) you need to calculate the NET force. If it's zero so velocity is constant. I hope I have helped you.
  • · Replies 33 ·
  • · Replies 62 ·
  • · Replies 19 ·
  • · Replies 18 ·
  • · Replies 49 ·
  • · Replies 54 ·
