Register to reply
How 4 atoms with the positions (0,0,0), (0,0,a), (0,a,0), and (a,0,0)?
by masyousaf1
Tags: atoms, positions
Share this thread:
masyousaf1
#1
Jun8-14, 12:32 AM
P: 11
We could have defined the supercell as
a cube with side length 2a containing four atoms located at (0,0,0), (0,0,a),
(0,a,0), and (a,0,0).
Kindly explain how can a cell with side length 2a is possible with the following postions (0,0,0), (0,0,a), (0,a,0), and (a,0,0) ?
Phys.Org News Partner Physics news on Phys.org
Technique simplifies the creation of high-tech crystals
Working group explores the 'frustration' of spin glasses
New analysis of oxide glass structures could guide the forecasting of melt formation in planetary interiors
Borek
#2
Jun8-14, 02:53 AM
Admin
Borek's Avatar
P: 23,400
What makes you think something is wrong with the cell?
masyousaf1
#3
Jun8-14, 03:09 AM
P: 11
I am unable to understand the positions of the atoms if we change the cubic lattice from 'a' to '2a'. The cell with lattice constant 'a' is primitive while with '2a' the cell is just a unit cell. Kindly explain the positions in case of cell with lattice constant 2a ? The original text (We could have defined the supercell as
(0,a,0), and (a,0,0) ) is taken from a book.
Borek
#4
Jun8-14, 03:47 AM
Admin
Borek's Avatar
P: 23,400
Would treating it as a cell with constant 'a' and positions (0,0,0), (0,0,a/2), (0,a/2,0) and (a/2,0,0) help?
I must admit I haven't dealt with these things for many years, but it looks like 'a' vs '2a' is just a matter of convention.
M Quack
#5
Jun8-14, 07:45 AM
P: 660
Borek is right. The new primitive lattice parameter of the supercell could be, say, A=2a or a'=2a, and
within this cell the positions are (a'/2,0,0) or (A/2,0,0), etc.
When you deal with this all the time you get tired of defining new lattice parameters and just use 2a directly.
Defining a supercell is just a first step. In the following step you make the atoms at (a'/2,0,0) different from the ones at (0,0,0), e.g. by attaching opposite magnetic moments, displacing them a little bit, etc. You cannot do that in the original cell because (in this case) there is only one atom that cannot be different from itself.
masyousaf1
#6
Jun8-14, 10:23 AM
P: 11
But why there are only four positions mentioned for atoms ? I think in case of cubic lattice constant of side "a" there is one atom per unit cell (each atom at corner is shared by 8 adjcent unit cells). But in case of cubic lattice constant of side "2a" there might be four atoms per unit cell (I am not sure). My question is that why there are four atoms per unit cell in case of "2a" and how the author described their positions ? Kindly help
DrDu
#7
Jun8-14, 10:42 AM
Sci Advisor
P: 3,567
I don't understand very well what you are asking or what the original statement of the book you are referring to are.
However, if you want to describe a primitive lattice with a cell of double side lenght, I would expect it to contain 8 atoms not four. Especially, there should be also atoms at (a,a,0), (a,0,a), (0,a,a) and (a,a,a), in addition to the ones you mentioned.
masyousaf1
#8
Jun8-14, 11:31 AM
P: 11
Kindly have a look at the orignal text "For example, we could have defined the supercell as
(0,a,0), and (a,0,0). Repeating this larger volume in space defines a simple
cubic structure just as well as the smaller volume we looked at above. There
is clearly something special about our first choice, however, since it contains
the minimum number of atoms that can be used to fully define the structure (in
this case, 1). The supercell with this conceptually appealing property is called
the primitive cell." First choice refers to cube with length "a".
Reference is DENSITY FUNCTIONAL
THEORY A Practical Introduction by DAVID S. SHOLL (Chapter 2 page number 36)
Book can be downloaded from
http://en.bookfi.org/s/?q=DENSITY+FU...troduction&t=0
Thank you for your attention
M Quack
#9
Jun8-14, 02:04 PM
P: 660
DrDu is right. If you double the side of the cube, you increase the volume by a factor of 2*2*2=8. So if in
the original primitive cubic cell there was 1 atom/a^3, then in the new cell there have to be 8 atoms/(8 a^3)
to get the same density.
masyousaf1
#10
Jun8-14, 11:28 PM
P: 11
Dear sir So what we conclude the text in the book is incorrect ?
M Quack
#11
Jun9-14, 01:48 AM
P: 660
Yes.
Register to reply
Related Discussions
Star Positions from the past to new positions-Precession Astronomy & Astrophysics 0
Chem help pleaseeee : How many Fe atoms and how many moles of Fe atoms are in 400.0 g Biology, Chemistry & Other Homework 6
Phd positions Academic Guidance 5
Why not sharp positions? Quantum Physics 25
REU Positions? Academic Guidance 4
