Power Needed to Keep 1000kg Object in Air
  • Thread starter anubodh
  • Tags
    Air
In summary, the power required to keep a 1000 kg object still in air using helicopter-like rotating blades is not a set amount and is dependent on various factors such as rotor size, shape, speed, air viscosity, and blade pitch. However, a general estimate can be made by looking at the thrust required to keep the object still, which can be calculated using various online calculators. Additionally, the first human-powered helicopter has twisted blades and can only hover, but further advancements may lead to a compromise between energy efficiency and faster horizontal flight.
anubodh
51
How much power (average) is required to keep a 1000 kg object still in air by putting a helicopter like rotating blades on it.(The entire weight of the motor to rotate the blades is included in 1000 kg).
There is no average; it is a function of rotor size: the larger the rotor, the lower the power. This is because lift comes from momentum change of the air (linear with velocity) while power comes from kinetic energy change of the air (a square function of velocity). But if you pick a rotor size we can walk you through the calc.
Please tell with respect to any rotor size.
I just want to know how much power i would be needing to keep it (1000 kg object) still in air at any height say 1 metre.
Sorry, I don't know any other way to say this: what you are asking is not possible. The answer you are looking for does not exist.
As Russ says, the answer could be anything from zero to an enormous amount of power. There's no set amount of energy expenditure required to hold an object in place.
maybe it's depend on the atmosphere pressure..
As I know, helicopter when fly have maximum height, because higher than that, the atmosphere pressure too low
A lot of factors affect the power required to be produced by the rotor to keep masses afloat in the air, like rotor shape, rotor size, rotor speed, air viscosity, pitch of the blades, etc. But you can look into the thrust required to keep the object still, which can be calculated. Then you can decide the rotor design and then the power of the motor.
A 1000 kg object can be kept afloat by a thrust of approx. 1000*g i.e., ~ 9806.65 N
Then there are some thrust calculators on the internet which you can use. Input the correct parameters so as to get your answer. Hope this helps.
http://www.heli-chair.com/aerodynamics_101.html
http://adamone.rchomepage.com/calc_thrust.htm
Wiki - propeller thrust
http://arc.aiaa.org/doi/abs/10.2514/8.11570?journalCode=jans
Perhaps look at the human-powered helicopter quest to get a ballpark figure. The feat is borderline attainable, so find out the weight of the craft and pilot, and you know the power a superfit athlete can develop for a short time, so just scale this up by x5 or x10, whatever. Regard this as the lower bound for your goal. :smile:
http://en.m.wikipedia.org/wiki/AeroVelo_Atlas
Helicopter and autogyro rotor blades are usually parallel, not twisted like a propeller blade.
With the helicopter, air moves downwards, through the power driven, forward tilted rotor, as a reaction to the generated lift. At any point in time only a short section of a non-twisted blade is actively generating lift. That working section moves continuously throughout the rotation. The lift area of the rotor is much less than the full rotor disk. The part not generating lift generates drag.
With an autogyro, air moves up through the free-wheeling rotor as the autogyro is pushed through the air by a separate propeller. Part of the blade is a turbine that drives the rotation, another part is an active lift generating section, the remainder is drag.
In order to generate a maximum lift to drag ratio, a twisted blade could be used. The problem then is that when flying horizontally, the lift will move to one side due to the apparent airspeed over the rotor surface being the sum of the vehicle airspeed and the rotor rotation.
Straight blades are inefficient but they are stable. The first human powered helicopter will have twisted blades and will hover only. Further advances will be a compromise between available excess energy and faster horizontal flight.
The energy needed to stay in the air is less if you don't want to go anywhere.
Any heavier than air machine must stay up there as a result of air being directed downwards - one way or another. We have regular threads about the theory of wings and flight and there is a lot of shouting about Bernouili, as if he outranks Newton when it comes to aircraft (haha).
When you look at an autogyro as a black box, you have a forward thrusting propellor which pushes the craft forward and, by a bit of clever aerodynamics, the passive rotor manages to defect air downwards, which provides the lift - just like any aircraft. There must be a difference between the speeds and volumes of the two air flows in the sections of the rotor to account for a net momentum change downwards - to give lift
This is interesting. What is the state of human powered helicopters? Human powered flight is one of those things that they have to go after but are doomed never to be doing it as well as birds and bats. It knackers me, just thinking of the effort involved to stay up there!
What is the formula for calculating the power needed to keep a 1000kg object in the air?
The formula for calculating the power needed to keep a 1000kg object in the air is P = mgh/t, where P is power, m is mass, g is gravitational acceleration, h is height, and t is time.
How does the height of the object affect the power needed to keep it in the air?
The higher the object is in the air, the more power is needed to keep it there. This is because as the object gains height, it gains potential energy which must be counteracted by an equal amount of power.
Is the power needed to keep a 1000kg object in the air constant?
No, the power needed to keep a 1000kg object in the air is not constant. It varies depending on factors such as the height of the object, air resistance, and external forces acting on the object.
How does air resistance affect the power needed to keep an object in the air?
Air resistance, or drag, acts in the opposite direction of the object's motion and requires additional power to overcome. The greater the air resistance, the more power is needed to keep the object in the air.
Can the power needed to keep an object in the air be reduced?
Yes, the power needed to keep an object in the air can be reduced by increasing the height of the object, reducing air resistance through streamlined design, and minimizing external forces acting on the object.
  • General Engineering
  • Mechanical Engineering
  • Classical Physics
