Not sure how to do this temp and freq problem
  • Thread starter Thread starter xxiangel
The discussion revolves around two physics problems: one concerning the relationship between the speed of sound in air and temperature, and the other regarding the frequency of a vibrating guitar string based on its length and tension. Participants are exploring the underlying principles of sound propagation and harmonic motion.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are attempting to relate the speed of sound to temperature using provided data and are questioning the assumptions behind the formulas for sound speed. They are also discussing how changes in string length and tension affect frequency, with some participants suggesting to examine the relevant equations.
Some participants have provided hints and guidance regarding the relationships involved in the problems, while others are encouraged to conduct their own research and share their findings. Multiple interpretations of the formulas and their applications are being explored, but no explicit consensus has been reached.
Participants note that the simplified relationship for the speed of sound in air is often used in high school physics, which may not account for all variables such as humidity. There is also mention of potential gaps in knowledge regarding specific concepts like the adiabatic bulk modulus.
xxiangel
Can someone help me work these out!?
1) A sound travels 1,047 meters in 3 seconds in air. Find the air temperature. (Answer 31.3 degrees C??)
2) A guitar string plays a fundamental frequency of 400 Hz. Find the
frequency played if the string were twice as long and twice as tight. (Answer is 283 Hz)
Do a bit of research in your textbook, or go to google and search on "speed of sound" and "vibrating string". Then give these a try on your own. If you still need some help, show us what you did.
Here are some hints:
1) In a perfect gas there is a relationship between the speed of sound, c, and the ratio of specific heats, [tex]\gamma[/tex], gravity, [tex]g[/tex], ideal gas constant, [tex]R[/tex], and temperature, [tex]T[/tex]. You have information to calculate c in your question.
2) There is an equation for calculating the fundamental frequency of a string. In that equation is the term for the length. What can you glean by doubling the length in that equation?
Let's see what you have done so far.
THere are two formulas for determining the speed of sound in air as a function of temperature. Chances are you have not covered the "adiabatic bulk modulus" of air and so you will be using the simplified relationship based on 331 m/s at 0 degrees C. For every degree above zero, the speed of sound is 0.6m/s faster.
This relationship is what is most often used in high school physics. This works within the short range of temperatures of human habitat (approx -10 to +40 degrees C) but does not factor in the humidity of the air.
FOr the second question, look in your text for how the frequency is proportional to length and tension. As you look at the formula, notice what would happen if you put a "2" in front of both tension and length.
  • · Replies 23 ·
42K
13K
10K
