Register to reply
Stainless steel crystal structure
by tau13
Tags: crystal, stainless, steel, structure
Share this thread:
tau13
#1
Jun12-14, 01:53 AM
P: 3
Hi,
I'm looking for a simple s.s crystal unit cell structure and can't find it anywhere.
I understand that stainless steel is a very general word and takes many forms and has many different types, but isn't there a standard type that people use in the industry and ususlay talk about when they use the word "stainless steel" like 316L which I've seen a lot..
Phys.Org News Partner Physics news on Phys.org
Technique simplifies the creation of high-tech crystals
Working group explores the 'frustration' of spin glasses
New analysis of oxide glass structures could guide the forecasting of melt formation in planetary interiors
DrClaude
#2
Jun12-14, 02:51 AM
Sci Advisor
PF Gold
DrClaude's Avatar
P: 1,325
Hi tau, welcome to PF!
Stainless steel is an alloy, and therefore does not have a simple crystal structure. Your question is a bit like asking what the chemical structure of a salt water molecule is.
For further reading, I suggest http://chemistry.about.com/cs/metals.../aa071201a.htm
tau13
#3
Jun12-14, 07:35 AM
P: 3
maybe you're the one who should do some reading: :-)
http://www.holland-hills.com/saltwaterchlorine.html
anyway, I know that the lattice information of Iron exists for the different forms that iron takes in different types of steel depending on its carbon content. I'm really searching for some kind of coordinates for performing simulations of stainless steel.
Astronuc
#4
Jun12-14, 08:01 AM
Admin
Astronuc's Avatar
P: 21,810
Quote Quote by tau13 View Post
Hi,
I understand that stainless steel is a very general word and takes many forms and has many different types, but isn't there a standard type that people use in the industry and usually talk about when they use the word "stainless steel" like 316L which I've seen a lot..
There are different types or grades of stainless steel for which the microstructure depends on the composition, including carbon content.
The three main groups are austenitic, ferritic and martensitic, and duplex combinations of these, e.g., austenitic-ferritic, ferritic-martensitic.
Austenitic steels have a predominant fcc structure, or γ-phase.
Ferritic is bcc (α or δ) structure.
Martensitics have a distorted tetragonal structure.
The microstructures depends on temperature at which the heat is quenched and quench rate.
http://www.keytometals.com/page.aspx...ite=kts&NM=153
There are also cementite, bainite, and pearlite.
DrClaude
#5
Jun12-14, 08:14 AM
Sci Advisor
PF Gold
DrClaude's Avatar
P: 1,325
Sorry, but a cute picture from the site of a vendor of pool equipment doesn't pass muster on PF
My point is that there is no "molecule of salt water," there are going to be solvated ions here and there in the solution, but no fundamental unit.
Again, the problem is that there is no base crystal stucture to s.s. You wont have a uniform crystal structure throughout the metal.
Here are some technical papers which deal with the subject of calculating the properties of stainless steel:
http://iopscience.iop.org/0965-0393/17/2/025010/
http://iopscience.iop.org/0965-0393/19/8/085008/
http://www.nature.com/nmat/journal/v...s/nmat790.html
tau13
#6
Jun12-14, 08:24 AM
P: 3
heehee... I was kidding. I'm a master student in chemical engineering :-)
I will look at what you've posted,
Astronuc I know that, but the crystal structure that is given is always for the Iron alone and I was wandering can simulations be made for SS.
nasu
#7
Jun12-14, 12:32 PM
P: 1,969
What do you mean by "for iron alone"?
Stainless steel is an alloy, the iron and chromium form a single crystalline structure (substitutional solid solution). The carbon atoms I believe are in the interstices of the lattice.
See solid solutions and alloys for more details.
SteamKing
#8
Jun12-14, 02:31 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,285
'wander' - walk or move in a leisurely, casual, or aimless way.
'wonder' - to think or speculate curiously.
Useful nucleus
#9
Jun13-14, 01:41 AM
Useful nucleus's Avatar
P: 250
As stated above Steel is an alloy. C, Cr, Mo, ....etc. can dissolve in iron or form precipitates. If they dissolve they can do this on interstitial or substitutional sites, also they may order or disorder, they may segregate to grain boundaries, dislocations,.....
Alloy theory is a vast topic. You may need to read more into it. But there is no such simple thing as the crystal structure of stainless steel.
DrDu
#10
Jun13-14, 05:44 AM
Sci Advisor
P: 3,555
As far as I remember, stainless steel contains lots of chromium, so that a thin sheet of chromium oxide forms on it's surface which hinders further corrosion.
So, it is a surface effect. The crystal structure of the bulk won't differ much from other highly alloyed steels.
Register to reply
Related Discussions
Friction of steel versus stainless steel General Physics 0
Iron/Stainless Steel Chemistry 8
Stainless Steel Materials & Chemical Engineering 9
Which stainless steel? Materials & Chemical Engineering 3
Stainless Steel Chemistry 10
