Register to reply
How electrons are excited in direct transitions?
by hokhani
Tags: electrons, transitions
Share this thread:
hokhani
#1
Jun12-14, 04:10 AM
P: 272
When a photon is radiated to a direct gap semiconductor and an electron is excited from valence band minimum to conduction band maximum, the applied force on the electron is zero (because k isn't changed) but the electron acquires energy. What is the source of the energy obtained by the electron in this transition?
Phys.Org News Partner Physics news on Phys.org
New complex oxides could advance memory devices
'Squid skin' metamaterials project yields vivid color display
Scientists control surface tension to manipulate liquid metals (w/ Video)
rigetFrog
#2
Jun12-14, 07:56 PM
P: 112
it's from valence band "max" to conduction band min.
Think of it in terms of excitation in an atom. You're going from quantum number n to n+1. There's an increase in energy associated with that. It corresponds with being "further" away from the nucleus.
This is the same story in bands. The valence band is "closer" to the nucleus and the conduction band is "farther" from the nucleus.
DrDu
#3
Jun13-14, 05:41 AM
Sci Advisor
P: 3,633
Quote Quote by hokhani View Post
The energy stems from the photon. I wouldn't say that the applied force is zero, as k isn't true momentum. The momentum of the photon is taken up by the lattice as a hole.
hokhani
#4
Jun13-14, 09:36 AM
P: 272
Quote Quote by DrDu View Post
I can not give exactly any idea about photon force, But I know that in an electric field:
[itex]Fexternal=d(\hbar k)/dt[/itex]
ZapperZ
#5
Jun13-14, 09:43 AM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,242
Not sure what that has anything to do with this. We clearly know that a photon has momentum, so when it is absorbed, there has to be a momentum transfer. But as DrDu has stated, this is taken up by the lattice of the solids as a whole, and it is not manifested in the energy transition of the electron. This is not just an isolated electron encountering a photon.
The reverse is also true. An electron in the conduction band decaying back to the valence band can emit a photon. While the electron may not have change any of its crystal momentum, clearly a photon that is emitted has a momentum. The recoil momentum is once again taken up by the crystal lattice.
Zz.
adjacent
#6
Jun13-14, 09:53 AM
PF Gold
adjacent's Avatar
P: 1,516
You can't use BBcodes inside latex, you should use " _ " for the sub scripts.
hokhani
#7
Jun13-14, 12:38 PM
P: 272
Quote Quote by adjacent View Post
Thank you. But using "_" I can only write one letter (for example: e) in the subscript and not more than one (for example: external).
adjacent
#8
Jun13-14, 12:45 PM
PF Gold
adjacent's Avatar
P: 1,516
Use _{Whatever you want} .
See,
[itex]F_{external}=\frac{\text{d}(\hbar k)}{\text{d}t}[/itex]
What I wrote is:
You can also right-click on my latex> show math as> Tex commands
DrDu
#9
Jun13-14, 01:31 PM
Sci Advisor
P: 3,633
Enclose them in curly brackets or use _\mathrm{ext} if you want them roman style.
ZapperZ
#10
Jun13-14, 01:32 PM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,242
I assume that your question has been satisfactorily answered (please acknowledge if it is, rather than let it hang) considering that we are now discussing how to do LaTex in this thread.
Zz.
DrDu
#11
Jun13-14, 01:33 PM
Sci Advisor
P: 3,633
[itex]F_\mathrm{external}=d(\hbar k)/dt[/itex]
This holds for the motion of wavepackets in one band, not for interband transitions.
ehild
#12
Jun14-14, 12:52 AM
HW Helper
Thanks
P: 10,772
You can imagine the interband transition like an elastic collision, for example, with a photon and the electron. As the photon has momentum p=h/λ, the momentum of the electron also has to change. But the momentum of the photon is much less than that of the crystal momentum at the Brillouin zone boundary so the transition looks almost vertical. Exactly vertical transition can happen by the assistance of an other particle, with a phonon.
ehild
Register to reply
Related Discussions
Excited electrons and spectral lines Advanced Physics Homework 2
How do electrons become excited in an atom Quantum Physics 2
Is there a direct magnetic interaction between two electrons? Quantum Physics 13
When the electrons in silicon are excited by visible light and jump Chemistry 1
Excited electrons Quantum Physics 1
