Why Is the Inverse Laplace Transform of This Function 2e^{-t} - e^{-2t}?
The discussion revolves around finding the inverse Laplace transform of the function (s+3)/((s+1)(s+2)). Participants are exploring the reasoning behind the expected result of 2e^{-t} - e^{-2t} and discussing the methods to arrive at this conclusion.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Some participants suggest using partial fractions to simplify the expression, while others express confusion about the necessity of this step. There are questions regarding the assumptions made in the textbook and the effectiveness of different approaches, including the use of tables for inverse Laplace transforms.
Participants are actively engaging with the problem, with some providing guidance on the use of partial fractions. There is acknowledgment of the challenges faced in understanding the problem, and multiple interpretations of the approach are being explored.
Some participants note that the textbook appears to assume a level of understanding that may not be shared by all, leading to discussions about the adequacy of the provided methods and the clarity of the problem setup.
cyberdeathreaper
I am asked to find the inverse laplace transform of the following function:
[tex] \frac{ \left( s+3 \right) }{ \left( s+1 \right) \left( s+2 \right) }[/tex]
Using tables, can anyone help me understand why the answer is:
[tex] 2e^{-t} - e^{-2t}[/tex]
I'm completely loss on this one, and yet the book assumes this is easily determined. Any ideas?
Note: I already realize that the bottom can be rewritten using partial fractions, but it seems to me that the book assumes that isn't even necessary - which makes sense, since it doesn't seem to get me anywhere anyway.
Look's like it might be this Heaviside formula for the ratio of polynomials. Have you encountered this before?
http://www.plmsc.psu.edu/~www/matsc597/fourier/laplace/node10.html
you have to do partial fractions that's all. [tex]\frac{\left( s+3 \right) }{ \left( s+1 \right) \left( s+2 \right) }= \frac{A}{s+1} + \frac{B}{s+2}[/tex]
s+3= A(s+2) + B(s+1)= (A+B)s + (2A+B)
A=2 B=-1
so you get
[tex]\frac{s+3}{(s+1)(s+2)} = \frac{2}{s+1} - \frac{-1}{s+2}[/tex]
from there you can see pretty simply from [tex]e^{at}= \frac {1}{s-a}[/tex] that you get the textbooks given answer.
Good grief...
That's totally correct Gale17 - thanks. I was trying to use partial fractions on just this part:
[tex] \frac{ 1 }{ \left( s+1 \right) \left( s+2 \right) }[/tex]
and then mutliply the answer by s+3. Obviously that was not getting me anywhere, because I still had an s term on the top to deal with.
Thanks again! :biggrin:
PS: OlderDan, thanks for the suggestion though. I don't think we have touched on that approach specifically yet, but based on your link, it does seem feasible.
an interesting way to use partial fractions... :wink: also, when you have the right answer, try working backwards with it.
you're welcome! (i like feeling useful anyways... sides, i have my own diff eq final coming up.. woo... )
The partial fraction approach is definitely the way to go. I thought you were looking for an alternative. That other thing might come in handy for higher order polynomials.
  • · Replies 17 ·
