Register to reply
Simulation of Compressed Air Driven Piston
Share this thread:
mmcc
#1
Jun13-14, 12:00 PM
P: 2
I am writing a MATLAB script that generates a dynamic simulation of a piston being driven by compressed air. My starting values for pressure and volume are as follows:
P0 = 14000000; %nm-2 or 140 Bar
V0 = 0.005; %m3 or 500cc
The simulation needs to be quite detailed and must take into account the following factors:
1. Force required to open the valve (assume hammer type)
2. Duration valve will remain open
3. Flow rate from valve and change over time
4. Expansion into transfer port over time
5. Force imparted to piston
6. Account for inertia and friction to move piston
7. Expansion into cylinder over time
8. Velocity, mass and force of air over time
I am looking for the necessary formulas to achieve the above goals.
Phys.Org News Partner Engineering news on Phys.org
Comfortable climate indoors with porous glass
Crash-testing rivets
Customized surface inspection
mmcc
#2
Jun14-14, 11:40 AM
P: 2
I suppose this is a lot to ask in one post, but I have made a start on this. I will run through the sequence of events and describe the formulas I have, or have identified so far.
The process begins with a hammer striking a valve to open the seal. This can be modeled as a collision over time and a series of forces (force of hammer, force of spring sealing valve and force of air pressure inside valve):
Force (change with time) = mass * acceleration (change with time)
Then simply conserve momentum over time:
Valve --- Kg m/s (change with time) ---> <--- Kg m/s (change with time)--- Hammer
Net force <--- Kg m/s (change with time) --->
Determining how long the valve will stay open is basic speed = distance /time. We can calculate the velocity using the conservation of momentum:
Force (Valve - change with time) + Force (Hammer - change with time) = Mass (Valve) + Mass (Hammer)
Mass / Force (change with time) = velocity (change with time)
We can then calculate the distance the valve seal will move and compare that with size/volume of the valve opening.
This then leads to air rushing into the valve and where the equation begin to become complex. I think I can model this as a flow through an orifice. As such, I have identified the following formulas (MATLAB comments):
% Density of air
% Assumed to be:
% 1. Sea level
% 2. 15 C
% d = p /Rs T
% where:
% d = air density (kg/m3)
% p = absolute pressure (nm-2) - 101325
% T = absolute temperature (K) - 288.15
% Rs = specific gas constant for dry air is 287.058 J/(kgK)
% d = 101325 / (287.058 * 288.15)
% d = 1.2249781262066510570904764201612 kg/m3
% Air Velocity
% v = 278.27 * (Math.sqrt(static pressure / Atmospheric density)
% v = 278.27261838130327370844581361742 * (Math.sqrt(13999999 / 1.225)
% v = 940,724.26425592028024204853937945 m/s
%v = 278.27 * (Math.sqrt(13999999 / 1.225)
% Flow through Orifice
% Q = Cd A [2 #p /Ad] ^ 0.5
% where:
% q = Flow rate (m3/s)
% Cd = Discharge coefficient
% A = surface area of opening (m2)
% #p = Pressure difference (change with time)
% Ad = air density
My question at this point is, can I model this as a flow through an orifice? If so, how do I determine the 'Discharge Coefficient' without experimental data?
Then how do I deal with the geometry of the transfer pipe between the valve and cylinder? What if it had a 90 degree turn, rather than being just a straight tube?
Finally, I notice that effects can be back-propagated in this system. Does this change any of the formula in any way?
Register to reply
Related Discussions
Convert crank driven system to an air piston one Mechanical Engineering 14
Hydraulic motor driven by steam/compressed air Mechanical Engineering 13
Two piston or 4 piston engine Mechanical Engineering 9
Single piston engine problem - position of piston Introductory Physics Homework 8
Oil between the piston and the casing manage to move with the piston? Mechanical Engineering 8
