Question regarding physical optics - (plane-polarized light)
The discussion revolves around a problem in physical optics, specifically concerning plane-polarized light and its interaction with polarizers. Participants are exploring the effects of polarizer orientation on light intensity and the calculations involved in determining the final intensity after passing through two polarizers.
  • Some participants seek clarification on the problem's requirements and the implications of the polarizer angles. Others discuss the intensity reduction factors associated with polarized light passing through multiple polarizers and question the interpretation of the problem's given answer.
Participants are actively engaging with the problem, with some offering insights into the calculations needed for intensity reduction. There is a recognition of differing interpretations regarding the problem's setup and the provided answer, indicating a productive exploration of the topic.
Some participants express uncertainty about the angles between the polarizers and the assumptions made in the problem statement. There is mention of an attachment containing the original question and solution, which may be influencing the discussion.
Sanosuke Sagara
I have my question,solution,doubt in the attachment that followed.Thanks for anybody that spend sometime on this question.
Please,I really need somebody help to explain to me what the question want so that I can have a better understanding of the question.Thanks for anybody that spend some time one this question.
The light entering the first polarizer is already polarized. There will be an reduction in intensity that depends on the angle of the polarizer relative to the direction of light polarization at each of the polarizers. The reduction at the first polarizer will not be 1/2. It appears you know how to find the intensity reduction when polarized light passes through a single polarizer. You need to apply that twice. At the second polarizer the angle will be 30 degrees, so the final intensity will be a factor that you can calculate, based on the angle, times the intensity in the middle region. The intensity in the middle region will be a similar factor (not the same factor) times the initial intensity. You need to figure out the two reduction factors so that their product is 1/4, resolve that into the individual reduction factors, and use the intensity reduction at the first polarizer to find the angle.
I can't make sense of the answer you say is given in the book. The way it is stated appears to contradict the statement that the two polarizers are at 30 degrees relative to one another. Make sure you are looking a the correct answer.
Thanks for your suggestion and the solution to this question,OlderDan and I really appreciate it.I will try to understand the question by myself.
  • · Replies 19 ·
  • · Replies 16 ·
