Why Are Statistical Significance Maps Used in Cosmic Ray Anisotropy Studies?
In summary, the conversation discusses the use of maps with relative intensity and statistical significance to determine the anisotropy of cosmic rays. The speaker is unsure about the purpose of the statistical significance maps and asks for an explanation. A link to a paper with an example of these maps is provided, but the speaker is still unsure about their interpretation. The conversation ends with a possible explanation for the negative values in the significance level.
vaart
Dear All,
I have a question regarding the understanding of anisotropy of cosmic rays and how to understand them better. To determine the anisotropy I have seen a lot of papers where they use maps that have a Relative Intensity map and a Statistical significance map of the sky.
I understand the relative intensity map, but I don't understand why the statistical significance maps are used, could some one explain this to me?
Thanks,
caart
Astronomy news on Phys.org
Hmmm... do you happen to have a link to one of the maps?
Sure, here is a paper that I have been recently reading.
http://arxiv.org/abs/1105.2326
It's figure 3 at page 15.
At section 3.2, they are explained but I don't really understand it yet, they say that they use the Li and Ma paper:
http://articles.adsabs.harvard.edu/cgi-bin/nph-iarticle_query?1983ApJ...272..317L&defaultprint=YES&filetype=.pdf
I'm actually not certain. At first glance I would think that the significance level depends on the intensity of the radiation and the observation time, with a higher significance corresponding to a higher chance that the signal is real and not a background fluctuation, but I'm not sure why the significance level goes into the negative.
Dear caart,
Thank you for your question regarding the use of statistical significance maps in understanding the anisotropy of cosmic rays. It is a valid question and one that is important to address in order to fully understand the research being conducted in this field.
To begin, let's define what we mean by anisotropy. Anisotropy refers to the directional dependence of a physical property, in this case the intensity of cosmic rays. In other words, the intensity of cosmic rays may vary depending on the direction they are coming from. This anisotropy can provide valuable information about the sources and mechanisms of cosmic ray production and propagation.
Now, let's discuss the use of statistical significance maps. These maps are used to determine if the observed anisotropy is statistically significant, meaning that it is not due to chance or random fluctuations in the data. This is important because cosmic rays are subject to various sources of noise and background signals, and it is crucial to differentiate between true anisotropy and random fluctuations.
The statistical significance map is created by comparing the observed cosmic ray intensity at each point in the sky to the expected intensity based on a uniform distribution of cosmic rays. The higher the significance level, the less likely it is that the observed anisotropy is due to chance. This allows researchers to confidently identify regions of the sky with significant anisotropy and investigate potential sources or mechanisms in those regions.
In summary, statistical significance maps are used to confirm the presence of anisotropy in the observed cosmic ray data and to distinguish it from background noise. They are a valuable tool in understanding the anisotropy of cosmic rays and furthering our knowledge of their origins and behavior. I hope this explanation has helped to clarify the use of these maps. Thank you for your interest in this topic.
Best regards,
What is a significance map?
A significance map is a graphical representation of the statistical significance of a particular event or phenomenon. It is used to visually display the level of confidence in the results of a study or experiment.
How is a significance map created?
A significance map is created by analyzing data using statistical methods and mapping software. The resulting map will show areas of high significance with different colors or symbols, allowing for easy interpretation of the data.
What is the purpose of a significance map?
The purpose of a significance map is to help researchers and scientists identify patterns, trends, and relationships in large datasets. It is also used to communicate the level of certainty in the results of a study to other researchers and the general public.
What factors affect the significance of a map?
The significance of a map can be affected by various factors, including the quality and quantity of data, the statistical methods used, and the assumptions and limitations of the study. It is important for scientists to carefully consider these factors when interpreting significance maps.
How are significance maps used in different fields of science?
Significance maps are used in a variety of fields, including biology, environmental science, social science, and geology. They can be used to study patterns in species distribution, identify areas of environmental concern, understand human behavior, and analyze geological features.
  • Astronomy and Astrophysics
  • General Discussion
  • Classical Physics
  • New Member Introductions
