Register to reply
Calculate all mid points of a line at a given interval
by Rich2020
Tags: interval, line, points
Share this thread:
Rich2020
#1
Jun19-14, 05:17 AM
P: 4
Hi guys & girls, I'm using Google maps coordinates to draw a line and want to divide the line by its length, giving segments where the length of each segment is equal to 1.
EG:
P1
p1.lat = 54.97435323116719
p1.lng = 54.9742647135445
P2
p2.lat = -1.6116368025541306
p2.lng = -1.6115100681781769
let's assume that the unit of measure is meter.
Now, between the points p1 and p2, I need to calculate the (x,y) every 1 meter - along the length of the line.
My attempt results in:
x = -0.000006809047899462957, y = 0.00000974879815028264
but I'm not sure if that is correct.
I use the formula:
x = (x2-x1) / distance
y = (xy-xy) / distance
Is this correct? If not, how can I do this?
Phys.Org News Partner Mathematics news on Phys.org
'Moral victories' might spare you from losing again
Fair cake cutting gets its own algorithm
Effort to model Facebook yields key to famous math problem (and a prize)
Simon Bridge
#2
Jun19-14, 06:11 AM
Homework
Sci Advisor
HW Helper
Thanks ∞
Simon Bridge's Avatar
P: 12,356
The formula you used is for the distance between points in a pane - latitude and longitude are points on the surface of a sphere. The distance between the two points is the curved distance across the surface of the Earth.
.Scott
#3
Jun19-14, 09:36 AM
P: 540
Quote Quote by Rich2020 View Post
P1
P2
I'm guessing that you meant:
P1
p1.long = -1.6116368025541306
P2
p2.lat = 54.9742647135445
p2.long = -1.6115100681781769
These are points near New Castle, England. These points are only about 10 meters apart and not too close to the North or south poles. So, unless we're sticklers for precision, we won't need to deal with spherical geometry and great circle distances.
Another approximation we will use is the shape of the Earth. We will assume a sphere of radius 6353 meters.
So, with this model:
1 degree of latitude = 2 pi R / 360 = (2 3.1416 6353 / 360) KM
= 110.881 Km
1 degree of longitude = 2 pi R cos(lat) / 360 = cos(54.974) 110.88 KM = 0.573944 110.88 KM
= 63.639 Km
Our deltas are P2-P1:
D
d.lat = 54.9742647135445 - 54.97435323116719 = -0.00008851762269
d.long = -1.6115100681781769 - -1.6116368025541306 = 0.0001267343759537
The length of D will be about:
√ ( (d.lat*110.881) + (d.long*63.639) ) Km = √161.3809 m
= 12.703 meters
So we need to divide D into 12.703 pieces, although you may want to round to 13:
S = D/12.703
S.lat = D.lat/12.703 = -.0000069679
S.long = D.long/12.703 = .0000099762
S is a step value, so the points will be P1 + nS where n=1, 2, ... 12.
Rich2020
#4
Jun20-14, 03:00 AM
P: 4
Thanks so much! Here is a link to the results in action: http://jsfiddle.net/FPby3/
I still need to tweek it a little but it's doing what I need so thank you very much! I shall name the marker array after you!
.Scott
#5
Jun20-14, 07:18 AM
P: 540
I am honored!
Register to reply
Related Discussions
Confused on how to calculate invariant interval. Special & General Relativity 17
Find slope of line, two points on the line are included Precalculus Mathematics Homework 2
Fourier Series Interval Points Differential Equations 1
Calculate point on line, perpendicular and intersecting another line in 3d space Differential Geometry 1
Two points on a graph, the mid-point of a line made by these two points is an origin. Precalculus Mathematics Homework 6
