Register to reply
Capacitor Charge Time
by OZwurld
Tags: capacitor, charge, time
Share this thread:
OZwurld
#1
Jun22-14, 03:05 AM
P: 7
Hello all,
I was reading this post on calculating the capacitor charge time:
http://www.physicsforums.com/showthread.php?t=145203
My problem is i have a capacitor (1000uF) and i want to determine its charge time but dont know the R value, is it something i chose arbitrarily or should it be in a datasheet.
Thanks.
Phys.Org News Partner Engineering news on Phys.org
An innovative system anticipates driver fatigue in the vehicle to prevent accidents
Squink personal factory aims to make circuit prototyping easy
Catching grease to cut grill pollution
MrSparkle
#2
Jun22-14, 03:27 AM
P: 104
It should come from the circuit. If your resistance is at or near 0, then your current is very large and your capacitor would fill up instantaneously.
OZwurld
#3
Jun22-14, 03:51 AM
P: 7
is there a typical value that i should use, or does that all depend on how much current i want?
sophiecentaur
#4
Jun22-14, 06:03 AM
Sci Advisor
PF Gold
sophiecentaur's Avatar
P: 11,882
Quote Quote by OZwurld View Post
In the limit, it absolutely depends upon the resistance (and the Inductance) of the rest of the circuit. In real life, a Capacitor is never charged "instantaneously". The leads and internal structure of the C will also have resistive and inductive components; when using Capacitors at RF, the self Inductance can be very relevant; any Capacitor can resonate and behave as a short circuit, open circuit or even an Inductor, above self-resonance.
Baluncore
#5
Jun22-14, 07:14 AM
Sci Advisor
Thanks
P: 1,715
The critical parameters relating to minimum charge time will be specified in the manufacturers data sheet.
1000uF will almost certainly be electrolytic, so the parameters will be;
1. ESR, the effective series resistance. 2. Ripple current, I_ripple. 3. Temperature rating.
If you try to charge an electrolytic capacitor too quickly, the high current flow may fuse the internal foil. That can also happen if you short circuit a capacitor. If you repeat the charge-discharge cycle often, the I2R power dissipated in the capacitor ESR may overheat the electrolyte. Keep the current below the ripple current specified.
To charge a capacitor, C, from a fixed DC voltage, V, through a resistor, R, will require the minimum resistor value to be R = V / I_ripple.
jim hardy
#6
Jun22-14, 08:43 AM
Sci Advisor
PF Gold
jim hardy's Avatar
P: 3,498
here's a pretty good overview of large capacitors
http://www.vishay.com/docs/28356/alu...troduction.pdf
Register to reply
Related Discussions
Capacitor charge time Engineering, Comp Sci, & Technology Homework 4
Time taken to charge capacitor to 2/3 V in Introductory Physics Homework 2
Time required to charge capacitor to percentage of max capacitor voltage Introductory Physics Homework 7
Time to charge a capacitor- please help Introductory Physics Homework 4
Time Constant / Capacitor Charge Time Introductory Physics Homework 19
