Vic88
- 1
If I used two magnet, each being able to lift a load of 100 lb, to repel each other, what will be the total repulsive force ?
The discussion revolves around the repulsive force between two magnets, particularly focusing on the factors that influence this force, such as distance, material properties, and temperature. Participants explore theoretical and empirical aspects of magnetism, including the application of Coulomb's law and the complexities of magnetic interactions.
Participants express various viewpoints on the relationship between lifting capacity and repulsive force, as well as the influence of material properties and temperature. There is no consensus on a definitive answer to the original question, and multiple competing views remain throughout the discussion.
Limitations include the dependence on specific material properties, the effects of temperature on magnetic behavior, and the unresolved mathematical steps in calculating the repulsive force between magnets.
krab said:Might sound stupid, but the point is that the amount you lift depends on the material you are lifting. So the two (what you can lift, and force of repulsion between magnets) are unrelated.
ShawnD said:It also depends on temperature. I saw a demonstration where a material was dipped in liquid nitrogen then placed over a magnet. The supercooled material floated over the magnet for maybe a minute until it heated up, then it dropped as if somebody cut a string holding it up.
