Register to reply
Photon upconversion
by BernieM
Tags: photon, upconversion
Share this thread:
BernieM
#1
Jun27-14, 10:39 PM
P: 130
I suppose this is a 2 part question.
I saw a neodymium YAG laser being used for UV experiments at University of Portland a long time ago. They put the yellow-green light of the YAG through a piece of (I believe if memory serves me well enough) calcite crystal and it emerged as UV. Does the calcite crystal also work for 478nm wavelength?
and
Is there a relatively common material that will give photon upconversion in the 478nm wavelength region?
Phys.Org News Partner Physics news on Phys.org
Technique simplifies the creation of high-tech crystals
Working group explores the 'frustration' of spin glasses
New analysis of oxide glass structures could guide the forecasting of melt formation in planetary interiors
DrDu
#2
Jun30-14, 04:37 AM
Sci Advisor
P: 3,562
I am not quite sure what you want: Double 478 nm or get 478 nm by frequency doubling?
In the second case you might want to check the article on laser pointers in wikipedia, especially on blue laser pointers:
http://en.wikipedia.org/wiki/Laser_pointer#Green
BernieM
#3
Jun30-14, 08:48 AM
P: 130
I am looking to simply bring IR photons into the visible or uv wavelengths.
Cthugha
#4
Jun30-14, 09:34 AM
Sci Advisor
P: 1,626
Photon upconversion
In principle any material with significant birefringence can achieve that. I guess simple second harmonic generation is what you are looking for. As that is a non-linear effect, you may need high intensities and therefore need some balance between reasonable birefringence and a good optical damage threshold.
Typical materials used for that purpose are lithium niobate, calcite and beta barium borate. KTP and LBO work just as well. The last few materials should be easy to get. It works at 478 nm. However, the key to second harmonic generation is phase matching inside the crystal, so you need a crystal which is cut in a certain way.
UltrafastPED
#5
Jun30-14, 09:40 AM
Sci Advisor
Thanks
PF Gold
UltrafastPED's Avatar
P: 1,908
You may have seen a Continuum Minilite:
http://www.quantronixlasers.com/inde...576#liintroTab
The YAG generates 1064 nm light; by inserting the appropriate crystals and dichroic mirrors it can be shifted to 532 nm, 355 nm, or 266 nm. There is loss of power with each conversion.
I used one of these a few years ago; I don't recall what type of crystals were used. On earlier projects I used BBO to shift from 780 nm to 390 nm, and a second crystal to convert that to 260 nm.
You can contact any of the optics houses for guidance on selecting appropriate crystals for a particular type of laser; for example: http://www.redoptronics.com/BBO-crystal.html
BernieM
#6
Jun30-14, 12:47 PM
P: 130
The answers you both have provided, answered my question very well. Thank you.
390nm would be great. 450 nm would be ideal.
Of the options mentioned, which provides the greatest efficiency?
Register to reply
Related Discussions
Upconversion fluorescence Chemistry 0
Mechanism behind photon absorption and photon emission Quantum Physics 4
If I acclerate and observe a photon, do I see the spin of the photon changing? Special & General Relativity 2
In electron/photon interactions does the handedness of the photon matter? Quantum Physics 2
Can photon-photon interactions alone produce black body radiation? Quantum Physics 12
