Core Material for Long-Run Solenoid Circuits
The discussion centers on selecting core materials for long-run solenoid circuits, focusing on efficiency, heat management, and magnetic properties. Participants explore various materials and their implications for electromagnet performance in a DC circuit operating at specific voltages and frequencies.
  • One participant is building a solenoid circuit and seeks advice on core materials that can handle long operating periods without overheating.
  • Another participant suggests that iron is the best core material due to its high magnetic permeability, which could enhance electromagnet strength while minimizing power consumption.
  • A different participant inquires about alternative materials or alloys that might offer lower hysteresis and higher permeability than iron.
  • One post mentions a brittle material used in TV tubes that has excellent magnetic properties, proposing it could be shaped with resin for use in electromagnets.
  • Some participants express skepticism about the necessity of using specialized materials, arguing that common materials like iron are sufficient for most applications.
  • Another participant raises the idea of using powdered iron or nickel iron cores to improve coil efficiency, aiming for greater flux density and reduced hysteresis, especially given the rapid on-off cycling of the electromagnet.
Participants generally agree that iron is a suitable core material, but there is no consensus on whether alternative materials could provide significant advantages in terms of efficiency and magnetic properties. The discussion includes multiple competing views on the best approach to core selection.
Participants express varying levels of experience and knowledge, which may influence their suggestions and claims. The discussion includes assumptions about the performance characteristics of different materials without definitive conclusions.
Individuals interested in electromagnet design, materials science, and circuit efficiency may find the insights and suggestions relevant to their projects.
Phaedrus
http://img16.imagevenue.com/img.php?loc=loc76&image=054_doorbell1.jpg
I am building a circuit such as the one above. The only difference is that it will be running for long periods of time. So heat becomes an issue. To make the most efficient and strongest electromagnet I am wondering what I should be looking for in core material. The cores will be 5/16" x 1 1/4" wrapped with 22 or 24 ga. magnet wire. This will be a DC circuit with voltages between 3-8 volts at around 1 amp give or take. Operating frequency will be between 80-160 Hz for long periods of time...like 20 minutes or more. There can be between 228-304 turns per coil...Not sure about this as the permeability and saturation is different for each core material. Also I'm trying to keep the resistance under 1 ohm per coil. If it means anything I will be using a capacitor in parrallel to the coils to catch the spark...usually a 30v 47uf.(incidentally if anyong can explain to me why changing the cap. value has such a drastic effect on the htz it would be greatly appreciated...I mean the cap. must be doing something besides just catching the spark...)
well, I am probably not as experienced as other people on this forum, but ill give my 2 cents
For the core, i think iron would be the best, it has the highest magnetic permeability, so you will get the strongest electromagnet possible, without using too much power in the coils. An ironm bol will work just fine and i find that the ones that are threaded just make winding the wire easier as it will give it some uniformity(not that it matters too much anyways)
As for the capacitor, it will probably be essential in creating the desired frequency of ring because capacitors discharge at constant intervals, so having a cap that will discharge every 120hz for example will cause the dc current moving towards the magnet to pulsate at 120hz, now this could be completely wrong, as i have little experience with capacitors
Iron is what I'm using now. I was wondering if there are better materials or alloys that would lend themselves better to this application...for lowest hysterysis...highest permeability...etc. Thanks for the reply.
i don't know its exact composition, but it is used in the deflection of electrons on the back of a TV tube..
it is a dark , kind of brittle material , which has outstanding magnetic properties.. maybe you could crush it up and form it to the shape that you want with some polyester resin..
that seems a bit overkill just to make an electromagnet(unless u need it to be super powerful with the very least amount of energy), anyways out of all the common materials you can easily get, iron is best
I agree iron is the best overall as far as availability and cost go. But what if I wanted to increase the efficiency of the coil...more efficiency = less voltage=less heat. I've been researching and have come across powdered iron cores...nickel iron cores...etc. Cost is not an issue. What I am looking for is a lead on what would give me the greatest flux density and since this will be turned off and on about 100 times per second I need the least amount of hysteresis...the least amount of magnetic memory...etc.
thanks
  • · Replies 32 ·
10K
13K
11K
12K
  • · Replies 35 ·
11K
