Register to reply
Why don't dishwasher door seals stop suds?
by Stephen Tashi
Tags: dishwasher, door, seals, stop, suds
Share this thread:
Stephen Tashi
#1
Jun29-14, 06:49 PM
Sci Advisor
P: 3,314
If you put laundry detergent or detergent for hand wiashing dishes into a dishwasher, you may get suds leaking out the seals around the door. Why are suds able to get past seals that are sufficient to stop water and water plus non-sudsing detergent?
Phys.Org News Partner Engineering news on Phys.org
'Smart material' chin strap harvests energy from chewing
Lockheed Martin advances live, virtual, constructive training in flight test
Lockheed Martin conducts flight tests of aircraft laser turret for DARPA
256bits
#2
Jul1-14, 04:58 AM
P: 1,498
Good question.
The water spray is not directed at the seals, so any splash should not leak out. Would, with a pressure differential, some air might leak out before water?
But with suds, they fill up the whole drum container. An expanding bubble would contact the seal, with the air forcing the thin film through the seal. It could be that the water level sensor does not register bubbles, and thus more water would be added to the dishwater with a bubbly producing detergent, since some of the water is in the form of bubble film.
I don't know how correct that is.
Borek
#3
Jul5-14, 06:13 AM
Admin
Borek's Avatar
P: 23,719
Perhaps the seal is good enough for water, but it leaks air (I think it has to, as the temperature inside is changing), and suds behave as air in this context? Or even better than air, when the surfactant is present on the water surface and helps wetting the seal?
Register to reply
Related Discussions
Wet dishes out of the dishwasher Chemistry 3
What is Best Temp H2O for Rinsing Dishes? Also, Efficacy of Soap Suds. Chemistry 10
Dishwasher - Voltage at metal cover Electrical Engineering 14
Dishwasher not cleaning Computing & Technology 22
Old Dishwasher Motor Electrical Engineering 5
