Register to reply
Half life determination
by sakkoyun
Tags: determination, life
Share this thread:
sakkoyun
#1
Jul4-14, 08:54 AM
P: 10
Hello,
I have a gamma spectrum of one element (X). There are several gamma peak in the spectrum. For example,
800 keV peak, 1000 keV peak and 1200 keV.
I have an information about the peak area changing with time. Namely, I know the peak area in different times. So I can calculate the half life of the element by using the area and time information.
But I have a problem.
I got 15 hours from 800 keV peak.
14 hours from 1000 keV.
16 hours from 1200 keV peak.
Which half-life is correct. What should I do? Which is the most reliable? Should I get average value?
Best wishes
Phys.Org News Partner Physics news on Phys.org
Engineers develop new sensor to detect tiny individual nanoparticles
Tiny particles have big potential in debate over nuclear proliferation
Ray tracing and beyond
Meir Achuz
#2
Jul4-14, 11:03 AM
Sci Advisor
HW Helper
PF Gold
P: 2,015
The widths of different peaks will be different.
Calculate the half-life, by measuring only the height of each peak.
These should all decrease at the same rate.
mfb
#3
Jul4-14, 02:43 PM
Mentor
P: 11,928
Quote Quote by Meir Achuz
Sure, but the widths should not vary with time. And if they did, you could use the height of the peak. There is no absolute value mentioned here, all values are relative.
Quote Quote by sakkoyun
You should find some estimate how precise your values are. For example, is your first value "15 hours plus/minus 2 minutes" or "in the range of 13 to 17 hours"? If those three values are compatible within the uncertainties, calculate the average. If the uncertainties differ significantly, a weighted average is better.
If the values are incompatible, it would be interesting to know more about the experiment. Do some lines come from decay products? That can give an activity that deviates from an exponential decay.
sakkoyun
#4
Jul6-14, 08:28 AM
P: 10
Thank you very much.
With the errors, 15 +-0.3
14+-0.1
16+- 0.5
The 1200 keV peak is more intense. The others are small peaks. Will I get an average of all them? Namely, (15+14+16)/3=15. Or, will I get the half-life as 16 due to the fact that 1200 keV is more intense. Or, will I get 14 for half-life due to the fact that this value is smallest error?
Best wishes
Vanadium 50
#5
Jul6-14, 09:02 AM
Mentor
Vanadium 50's Avatar
P: 16,385
Quote Quote by sakkoyun View Post
Quote Quote by mfb View Post
mfb
#6
Jul8-14, 12:52 PM
Mentor
P: 11,928
14+-0.1 and 16+- 0.5 are a bit far apart. It would be interesting to see the decay scheme. If there is a physical reason for them to have the same half-life, something went wrong, you were really unlucky (>3 standard deviations) or the uncertainties are non-gaussian.
sakkoyun
#7
Jul9-14, 02:38 AM
P: 10
Zn68 was created after reaction. 3 gamma peak are clear in gamma spectra. 805, 1077 and 1260 keV. After analyzing each three peaks individually, I got three different half-life values. (Analyzing is performed by investigating the peak area with time. And obtaining decay (growth) curve). Which one is more reliable? Or ?
mfb
#8
Jul9-14, 04:05 PM
Mentor
P: 11,928
And what did you have before?
Did you identify the gamma energies in a decay scheme?
How exactly did you do this?
sakkoyun
#9
Jul10-14, 01:37 AM
P: 10
Ga69 was bombarded by 10 MeV photon. A neutron was emiited from Ga69. The unstable Ga68 decayed to Zn68.
Vanadium 50
#10
Jul10-14, 03:55 AM
Mentor
P: 16,385
None of those are near the half life of Ga-68. Are you sure you are measuring what you think you are?
sakkoyun
#11
Jul10-14, 04:01 AM
P: 10
I was choosen the numbers randomly for an illustration. Actually the half lives that I measured are 65 min, 67 min and 66 min.
Vanadium 50
#12
Jul10-14, 05:21 AM
Mentor
P: 16,385
I'm afraid by asking people to help you with made up, inconsistent numbers, you ended up wasting people's time. Perhaps it would be better to show us the real numbers.
sakkoyun
#13
Jul10-14, 05:35 AM
P: 10
My aim is to know the technique with a basic examples. It is not do an article all together. I have no realistic data. Again, I would like to know the technique. Because of someone, I made up an element, a realistic peaks and a realistic half life.
I do not have any of them. Just technique I wonder. A dream I had about this problem. So I ask to get an answer. Thats all.
Vanadium 50
#14
Jul10-14, 05:55 AM
Mentor
P: 16,385
It's difficult to help you if you don't provide consistent information.
mfb
#15
Jul10-14, 03:19 PM
Mentor
P: 11,928
The right analysis method depends on all those details you refuse to give.
Register to reply
Related Discussions
Help With Half Life Atomic, Solid State, Comp. Physics 1
Half life of K Introductory Physics Homework 1
Short hlaf life and long half life of epinephrine Biology 0
Half-Life real life application question Introductory Physics Homework 0
Half Life and Half Life 2- The computer games General Discussion 25
