Register to reply
Completely dissolving a gas into a liquid
by warfreak131
Tags: completely, dissolving, liquid
Share this thread:
warfreak131
#1
Jul6-14, 09:00 PM
P: 181
Hello PF
I want to dissolve a gas in a liquid. I figured I could create a closed loop vacuum system. I introduce gas into the lines at atmospheric pressure, and then close off the lines, so the intake and exhaust of the vacuum pump are connected. Then I turn the pump on and the gas just runs through the liquid again and again and again until its completely dissolved.
Do you think that would work?
Phys.Org News Partner Engineering news on Phys.org
Researchers find security flaws in backscatter X-ray scanners
Virtual reality guides those whose memory is failing
Intelligent navigation system to personalise shopping trips
SteamKing
#2
Jul6-14, 09:28 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,471
It's not completely clear what you are trying to accomplish.
A given amount of liquid will be able to hold only so much gas, depending on the ambient temperature and pressure of the liquid. If the liquid reaches its saturation temperature for its pressure, it cannot hold any dissolved gasses at all. This is a consequence of Henry's Law:
http://en.wikipedia.org/wiki/Henry%27s_law
warfreak131
#3
Jul6-14, 09:46 PM
P: 181
Ok, I'll try to clarify. (see attached pic) Let's say I want to re-carbonate soda that's gone flat. I would put soda in a vessel which will allow CO2 to pass through it. And then the CO2 just flows through the soda again and again until its dissolved as much as possible.
If I cool down the liquid, more gas would be able to dissolve correct? Also, if gas makes it through the liquid without dissolving, will at least cool down, making it more likely to dissolve on the second pass?
SteamKing
#4
Jul6-14, 11:21 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,471
You might get some CO2 to re-dissolve, but nowhere near the amount of CO2 the liquid originally contained. That's why soda pop is bottled under pressure: the higher pressure means more CO2 gas is dissolved, and when you open the container and release this pressure, some of the CO2 comes out of solution and makes the bubbles appear.
And using a vacuum pump just means you are lowering the pressure of the liquid, which in turn reduces the saturation temperature of the liquid, which means less gas is going to dissolve in the liquid.
Since you are specifically talking about carbonation, perhaps this article might help:
http://en.wikipedia.org/wiki/Carbonation
warfreak131
#5
Jul7-14, 08:11 PM
P: 181
Hmmm, then what would be the best way to maximize the amount dissolved? I was thinking, if I added a 1 way valve into the system, then it would draw in air consistently as long as the system isnt at atmosphere. So if anything happened where the pressure of the soda wasn't at atmosphere, the 1 way valve would allow air in, restoring the pressure.
Otherwise, whats a good way to carbonate something. I know that product soda-stream uses a compressed CO2 cylinder and you just add a few blasts of CO2 to the soda. So would it be better to compress the gas first?
SteamKing
#6
Jul7-14, 09:33 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,471
Yes.
Register to reply
Related Discussions
Dissolving carbon dioxide from air without dissolving any other gases. Chemistry 2
Dissolving a plastic without dissolving freeze/thaw treated PVA Materials & Chemical Engineering 0
Pascal's Law - pressure inside the liquid vs. force needed to lift the liquid Introductory Physics Homework 1
Using mass of copper in both air and liquid to find density of liquid? Introductory Physics Homework 7
Dissolving CO2 Chemistry 1
