Register to reply
Carbon steel fatigue and temperature properties
Share this thread:
Qluq
#1
Jul7-14, 07:42 AM
P: 14
Hi everyone,
I need some specific mechanical properties of A516 carbon steel, but as yet I am unable to find it online. Can you help me find the fatigue limit and the relation between yield strength and temperature? Are there tabulated values for this?
Thanks!
Mark
edit: found it! seems i need the ASME Boiler and Pressure Vessel Code part 2: materials section D: properties...
Phys.Org News Partner Engineering news on Phys.org
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
New filter technology uses inert gas to bore holes in high-quality steel
Greg Bernhardt
#2
Jul10-14, 04:33 PM
Admin
Greg Bernhardt's Avatar
P: 9,562
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
Qluq
#3
Jul11-14, 10:56 AM
P: 14
Thanks Greg,
no worries! i found where i can find the data i need and had already put it in the edit of the opening post. that's probably why nobody has reacted.
Astronuc
#4
Jul13-14, 11:41 PM
Admin
Astronuc's Avatar
P: 21,875
One pretty much has to buy the appropriate ASME BPV section/case for a code/case material.
ASM has some books, including one on Carbon steels, but they are fairly general. If one is using a case, then buy the appropriate documentation.
Register to reply
Related Discussions
Fatigue calculations for stainless steel seamless tubing Mechanical Engineering 0
Fatigue Properties of Duplex Stainless Steel Materials & Chemical Engineering 1
Ductile to brittle transition temperature of low carbon steel General Engineering 0
Quenching plain carbon steel and alloy steel, hardness question? Engineering, Comp Sci, & Technology Homework 0
Fatigue Properties of Chinese steel Materials & Chemical Engineering 1
