Register to reply
Start planting trees on mars now
by howabout1337
Tags: mars, planting, start, trees
Share this thread:
howabout1337
#1
Jul7-14, 12:06 PM
P: 21
Can we start planting trees on mars now? Considering that there are so many tree species on earth that lives in extreme conditions, at least one of them would survive on mars right?
Imagine what mars would be like in 50 years if we started doing this now.
Phys.Org News Partner Astronomy news on Phys.org
Young binary star system may form planets with weird and wild orbits
Evidence of a local hot bubble carved by a supernova
Astronomers measure weight of galaxies, expansion of universe
DrStupid
#2
Jul7-14, 12:25 PM
P: 464
Quote Quote by howabout1337 View Post
Trees doesn't even survive arctic climate on Earth and Mars is far more hostile. Maybe it would be possible with some extremophiles or genetic modified organisms but I think it would be a very bad idea to contaminate Mars with alien lifeforms.
howabout1337
#3
Jul7-14, 12:33 PM
P: 21
I just thought if we start now, mars' atmosphere will be like earth's in ten thousand years.
Vanadium 50
#4
Jul7-14, 12:44 PM
Mentor
Vanadium 50's Avatar
P: 16,191
Quote Quote by DrStupid View Post
I fail to see how a bunch of dead trees will help that.
DrStupid
#5
Jul7-14, 12:44 PM
P: 464
Mars' atmosphere will never be earth-like because there is not enough nitrogen. It might be possible to make it breathable or at least suitable for plants but terraforming Mars requires much more than just planting trees and would be even more unethical.
Bandersnatch
#6
Jul7-14, 12:59 PM
P: 697
It won't because you can't plant them there.
Trees need liquid water and nutrients in the ground, and lots of oxygen and carbon dioxide in the atmosphere.
You can't have liquid water in low pressure, low temperature environment. The nutrients have to be imported from offworld, as there's no bacteria, and little nitrogen in the air to produce them on site.
The atmosphere is so thin, it's almost vacuum. So even though there's lots of CO2 by percentage, there's almost none to use for building the actual tree and sugars to burn later for energy. There's even less oxygen for burning those sugars.
Have a read through this breakdown of tree physiology before proceeding:
http://mff.dsisd.net/Environment/TreePhys.htm
Chronos
#7
Jul7-14, 04:32 PM
Sci Advisor
PF Gold
Chronos's Avatar
P: 9,386
Many scientists suspect Mars had an earth like atmosphere in the distant past. Unfortunately, it is too small and its intrinsic magnetic field is too weak to retain such an atmosphere. See http://www.universetoday.com/97331/s...ts-atmosphere/ for discussion.
.Scott
#8
Jul8-14, 07:41 AM
P: 540
Martian lacks a strong magnetic field - and I believe that is the most important reason that it would not be able to hold onto any atmosphere denser than what it already has.
http://science.nasa.gov/science-news...01/ast31jan_1/
Mars isn't so fortunate. Lacking a planet-wide magnetic field, most of the Red Planet is exposed to the full force of the incoming solar wind. "The Martian atmosphere extends hundreds of kilometers above the surface where it's ionized by solar ultraviolet radiation," says Dave Mitchell, a space scientist at the University of California at Berkeley. "The magnetized solar wind simply picks up these ions and sweeps them away."
iDimension
#9
Jul8-14, 10:04 PM
P: 23
Plant 1trillion trees and they'll die before they can grow. There is radiation from the sun, extremely cold weather, and no water... The only way it can be done is to create a huge radiation proof dome that is filled with oxygen tanks. We can live on Mars but it has to be inside a protective dome. Teraforming a planet is a long way away I think.
strangerep
#10
Jul8-14, 11:10 PM
Sci Advisor
P: 1,908
Quote Quote by Vanadium 50 View Post
Benit13
#11
Jul9-14, 04:40 AM
P: 7
I propose we plant more trees on Earth first!
howabout1337
#12
Jul9-14, 01:55 PM
P: 21
Lol, I know most of you think it's a silly dream, but I think there is something on earth that will survive mars' harsh condition. http://www.planetary.org/blogs/guest...vive-mars.html
Chronos
#13
Jul9-14, 02:34 PM
Sci Advisor
PF Gold
Chronos's Avatar
P: 9,386
This has been studied to a limited extent, e.g., http://arxiv.org/abs/1002.4077, Bacterial survival in Martian conditions.
tarzan322
#14
Jul10-14, 05:05 PM
P: 3
It could be possible to give Mars a magnetic field through man made means. Supposedly, we have made magnets that are just as powerful as Earth's magnetic field. And if you wanted to terraform the planet, you wouldn't start with trees anyway. You would start with algae, which is what is believed to have created most of the oxygen here. It uses far less resources, so it requires much less to survive, and could be genetically engineered to work in the environment on Mars.
Chronos
#15
Jul11-14, 01:02 AM
Sci Advisor
PF Gold
Chronos's Avatar
P: 9,386
The question remains, where do you get the energy to power the magnets.
tarzan322
#16
Jul12-14, 05:24 PM
P: 3
Quote Quote by Chronos View Post
Well, if your familiar with Mars One, putting a colony on Mars is going to bring that question up anyway. At some point, they are going to have to find way to power the colony. There's always solar, but it won't be as effective as it is here on Earth. They have seen dust devils on Mars, so there is possibly some wind. And then there is always Nuclear, which is probably the best bet considering there is no environment to ruin anyway, but it provides the most amount of power. Of course it would also be amusing to see environmental groups in an uproar over the use of nuclear energy on a world with no environment.
phinds
#17
Jul12-14, 06:47 PM
PF Gold
phinds's Avatar
P: 6,123
Quote Quote by tarzan322 View Post
"No environment" is a ridiculous concept. Of COURSE there is an environment, it's just different than ours and less complex.
Saying that there is no environment is equivalent to saying that if you get zero as a result of a calculation that means there is no result at all.
phinds
#18
Jul12-14, 06:48 PM
PF Gold
phinds's Avatar
P: 6,123
Where do you get the water to grow the algae in?
Register to reply
Related Discussions
How to start generator with battery (self start) with ignition. Electrical Engineering 12
Mars-One: People living on Mars in 2023 General Discussion 63
Where to start learning more about and start building interest in EE? Electrical Engineering 16
Mars Now - Third Alternative To NASAs Mars Who Knows When Program General Discussion 36
Manned Mars mission to Mars before 2020? Aerospace Engineering 70
