Register to reply
General-Purpose and RF JFET and MOSFET
by Fischer777
Tags: generalpurpose, jfet, mosfet
Share this thread:
Fischer777
#1
Jul9-14, 02:15 AM
P: 84
Hey guys,
I'm looking for some general-purpose N-channel JFET and/or MOSFET transistors (depletion-zone) to be used as audio frequency and radio frequency amplifiers (although probably not higher than 50 MHz). They likely won't be subject to voltages over 12 volts or current higher than 200 milliampers. I've tried searching mouser and google but all I seem to be able to find are power MOSFETs. You guys know of any that would be work?
Thanks
Phys.Org News Partner Engineering news on Phys.org
DIY glove-based tutor indicates muscle-memory potential
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
vk6kro
#2
Jul9-14, 09:35 AM
Sci Advisor
P: 4,032
BF981 dual gate Mosfets seem to still be readily available on EBay. They cost as little as $1 each if you buy 5 or 10.
These work well to above 200 MHz as low noise amplifiers or mixers.
There are plenty of circuits on Internet using this device.
They do have a low output impedance, so circuits that put a parallel tuned circuit directly across the output of these devices should be treated with suspicion. Such circuits will be severely damped by the low output impedance.
The output of the BF981 should be connected to a tap on the coil of a tuned circuit.
Currents of 10 or 20 mA are typically used with these FETs.
Baluncore
#3
Jul9-14, 01:56 PM
Sci Advisor
Thanks
P: 1,923
Depletion mode from Element14.
INFINEON - BSS126 H6327 -MOSFET, N-CH, 600V, 21MA, SOT23 Vgs = -2V
INFINEON - BSP129 L6327 - MOSFET, N-CH, 240V, 350MA, SOT-223 Vgs = -1.4V
http://au.element14.com/jsp/search/b...atchallpartial
Also;
Jaycar.com.au have JFETs, MPF102 and MPF106, but they are only 10mA.
davenn
#4
Jul9-14, 05:24 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,665
the J309 and J310 are also a great small signal FET's
have used in many receiver projects
dunno if you could push them to 200mA tho, without looking at the datasheet
To the OP, you haven't really stated what you want these FET's for ??
receiving or transmitting ??
The IRF510 is a popular FET device for use in 1 -50Hz for a transmitter
there's dozens of sample circuits on google
single device will give you ~ 10W and there are example circuits of ones used in parallel
Dave
Fischer777
#5
Jul9-14, 06:43 PM
P: 84
It's for a project that requires me to send and receive an FM signal at about 50 MHz. I was planning on using FET transistors for all the low powered oscillation, mixing, and amplifying stages, and possibly the transmitter output and audio output stages. The transmitter doesn't have to be very powerful, in fact, for it to work as a class 15 device it has to have a range of less than 200 feet, so I'm aiming for a low-powered transmitter in the milliwatt range. The audio output should be powerful enough to drive earphone speakers, but for that I could use a BPJ buffer.
Register to reply
Related Discussions
Interpreting MOSFET ID/Vds curve for a MOSFET Switch Electrical Engineering 1
What is the purpose of the general purpose registers, segment Electrical Engineering 4
A JFET vs MOSFET discussion. Electrical Engineering 2
JFET-JFET cascode amplifier Electrical Engineering 2
General purpose solver General Math 1
