Register to reply
Stepper motor increase rpm but keep torque
by nomisme
Tags: increase, motor, stepper, torque
Share this thread:
nomisme
#1
Jul10-14, 06:24 AM
P: 19
Is it possible that I keep the typical working torque but increase the rpm by raising my voltage to my motor?
I have this motor and control board:
http://uk.rs-online.com/web/p/stepper-motors/3514631/
http://uk.rs-online.com/web/p/steppe...PSF_421243|acc
My current rpm is just 3.5rpm which is too low to my desired 18rpm but I will need to keep the torque to go on.
please help.
Phys.Org News Partner Engineering news on Phys.org
'Smart material' chin strap harvests energy from chewing
Lockheed Martin advances live, virtual, constructive training in flight test
Lockheed Martin conducts flight tests of aircraft laser turret for DARPA
Simon Bridge
#2
Jul10-14, 07:51 AM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 13,067
increasing the voltage usually increases the rpm and the torque.
Mind you, if the step timing is a constant then, although the motor spends less time doing each step, the average speed should stay the same.
Changing the average speed of the motor, then, involves making more steps per second.
So what controls that?
256bits
#3
Jul10-14, 09:03 PM
P: 1,497
Generally, increasing the voltage to the stepper motor is done to provide more torque. If undertorqued, the stepper motor will not advance to the next step, ie it will not turn.
tygerdawg
#4
Jul12-14, 07:24 AM
P: 158
Your motor should have a torque-voltage-RPM curve given by the manufacturer. Your answer is there.
Register to reply
Related Discussions
Can gears increase Holding Torque of a stepper motor? Mechanical Engineering 6
Stepper Motor Current-Torque theory Electrical Engineering 0
Driving a compact can crusher- stepper motor or gear motor? Mechanical Engineering 12
Stepper Motor Torque Characteristic Measurement Introductory Physics Homework 4
Stepper Motor Torque Mechanical Engineering 2
