Hide Drive and restrict data/folders access
  • Thread starter Thread starter darkar
    Drive
The discussion revolves around methods to hide a drive from guests and restrict access to specific folders. Participants explore various software options and technical approaches, including operating system settings and encryption techniques.
  • One participant inquires about how to hide a drive and restrict folder access, mentioning the search for software recommendations.
  • Another participant suggests a method involving admin mode and drive properties to make folders private, noting that the process may vary by operating system.
  • Several software options are mentioned, including Folder Guard and CleanSlate, with participants sharing their positive experiences.
  • A participant recommends Winfilter for its profile feature and various capabilities, including hiding drives and files.
  • One participant emphasizes the importance of formatting the hard drive in NTFS for better security and describes how to set permissions for users.
  • Another participant suggests encryption as an alternative method to secure data, highlighting its effectiveness against overriding permissions.
  • A later reply corrects a typographical error regarding NTFS and reiterates the recommendation for encryption as a crucial step for data security.
Participants express a range of opinions on the best methods and software for hiding drives and restricting access, with no clear consensus on a single approach or solution. Some participants agree on the importance of NTFS and encryption, while others focus on specific software recommendations.
Participants mention various operating systems and software, but the discussion lacks detailed exploration of specific configurations or potential limitations of the suggested methods and tools.
This discussion may be useful for individuals seeking to enhance data security on their computers, particularly those interested in software solutions and technical methods for restricting access to drives and folders.
darkar
Hello,
How can i hide a drive from guests and restrict them from accessing those folders?
I also found many softwares from search. Anyone using one? If so, which software u recommend?
Thank You.
Computer science news on Phys.org
To restrict access to a drive: Log into admin mode, simply right click on the drive and click on "properties". Then click on "Sharing"...then check "make this folder private" Ofcourse, this varies from OS to OS, but should be approximately the same. I do not know much about any software that can do this.
I found a software calls folder guard. and it seems work well :P
I have used cleanslate and found it satisfying.
Can I recommend Winfilter?
I was really impressed by its profile feature (it help me switch system
configuration easily and quickly).
It also includes the following features:
hide drives and files
hide start menu icon
hide program shortcuts
hide desktop icons
To know more detail, please check their website (http://updownsoft.com )
The best way to secure things and to keep the contents of your drive private is to format your hard drive in the NTSF format.
Then log on as an administrator - right click on the drive in my computer - select properties and then on the security tab ,which i don't believe you get if your hard drive is formatted as FAT32.
Then its a simple matter of highlighting a user name and ticking a box against the different permissions you wish to give that user for that drive.
You may need to add a user which is a simple matter of clicking on the advanced tab and adding them .
Most importantly don't forget to give yourself permission before you apply your setting. I find its always good to have a second account which has full access to everything just in case.
An alternative is to encrypt the data.
Dont you mean NTFS? :smile: anyway I would also recommend NTFS on Windows to lock down access to your data. The best way is what MeJennifer has suggested, encryption. If you don't encrypt your data, it is quite easy to override any NTFS permissions you give folders, and files. (Just boot into Konppix for example).
  • · Replies 35 ·
  • · Replies 22 ·
  • · Replies 24 ·
11K
10K
