Register to reply
How effective are honeycomb plates at preventing "bend"?
by Nikita240
Tags: bend, effective, honeycomb, plates, preventing
Share this thread:
Nikita240
#1
Jul15-14, 03:43 AM
P: 2
I'm designing a custom ultra stiff strut bar for a car. Achieving extreme stiffness usually adds a lot of weight, so I am looking into ways to reduce the weight.
Honeycomb plates are extremely light, but are only stiff in certain directions. This is perfect for my application since I am transferring forces in a very controlled manner.
My question is, how stiff are honeycomb plates under bend? That is, one side being held perfectly perpendicular, and a force applied tangentially to the other end.
Also, in what direction is the honeycomb strongest?
Thanks.
Phys.Org News Partner Engineering news on Phys.org
Future phones to use blood and speech to monitor HIV, stress, nutrition
Neuron circuit may enable pitch perception applications
Quasi-distributed temperature sensors from draw-tower fabrication technology
AlephZero
#2
Jul15-14, 07:09 AM
Engineering
Sci Advisor
HW Helper
Thanks
P: 7,104
The manufacturers provide all the technical data you need to answer these questions, usually as the equivalent "smeared out" material properties ignoring the finite size of the cells.
For example see http://www.hexcel.com/Resources/Data...Technology.pdf
Honeycomb is anisotropic because of the way it is made, A set of flat strips are bonded together, and then pulled apart to form the cells, rather like making a Christmas decoration with paper and glue. This means the thickness is doubled where the strips are bonded. See the PDF for more.
Nikita240
#3
Jul16-14, 03:07 AM
P: 2
Quote Quote by AlephZero View Post
I order from McMaster, and they don't provide that much detail unfortunately.
That is actually very helpful! Thanks!
After reading that, I understand that it's only strong in the L direction, which is the direction in which the honey comb "ribbon" is weaved.
Register to reply
Related Discussions
Sheldon Axler's "Algebra & Trigonometry" vs. "Precalculus: A Prelude." Science & Math Textbooks 30
What are the differences between "infinite" and "eternal"? General Discussion 2
Difficulty understanding "donor" and "acceptor" energy levels. Atomic, Solid State, Comp. Physics 6
"Special" and "General" relativity- Who invented those terms? Special & General Relativity 2
How is "cross sectional area" different from "area"? Introductory Physics Homework 5
