Register to reply
Harmonic waves
by manimaran1605
Tags: harmonic, waves
Share this thread:
manimaran1605
#1
Jul18-14, 10:07 AM
P: 53
What is the difference between propagation number(K) and wave number(k) described in Optics book written by hecht
He defined K=2π/λ and k=1/λ and both of them have the same units (i.e, meter inverse)
What does wave number of a Harmonic function tells about?
Phys.Org News Partner Physics news on Phys.org
Step lightly: All-optical transistor triggered by single photon promises advances in quantum applications
The unifying framework of symmetry reveals properties of a broad range of physical systems
What time is it in the universe?
olivermsun
#2
Jul18-14, 01:54 PM
P: 788
The units look the same, but they aren't quite the same. It's a somewhat confusing notation in my opinion (especially when you use 'K' and 'k'!)
K=2π/λ is in units of radians/m and k=1/λ has units cycles/m, where "radians" and "cycles" are usually omitted. You just have to remember which kind of units you're using, so you know whether there needs to be a factor of 2π inside the sine/cosine/exponential.
For example, a wave of "propagation number(K)" would be sin(Kx), while a wave with "wave number(k)" would be sin(2πkx).
jtbell
#3
Jul18-14, 04:24 PM
Mentor
jtbell's Avatar
P: 11,779
Quote Quote by manimaran1605 View Post
[Hecht] defined [propagation number] K=2π/λ and [wave number] k=1/λ
You have it backwards. He defines the propagation number as ##k = 2 \pi / \lambda## (lower-case Latin letter "k") and the wave number as ##\kappa = 1 / \lambda## (lower-case Greek letter "kappa", not upper-case Latin letter "K"). Those different symbols (##k##, ##\kappa##, and ##K## in LaTeX; or k, κ, and K in PF's default font) tend to confuse people. Look carefully!
As olivermsun noted, the units are different. ##k## is much more commonly used. ##\kappa## is mainly used by spectroscopists. I don't know if they have a practical reason for it, or if it's just a historical convention.
olivermsun
#4
Jul18-14, 04:45 PM
P: 788
Harmonic waves
The ##k = 2 \pi / \lambda## version is often convenient for working with waves when you also use the angular frequency ##\omega = 2 \pi / T## (where ##T## is the wave period).
That way, you can write things like ##e^{i(kx - \omega t)}## without having ##2\pi##s all over the place.
jtbell
#5
Jul18-14, 04:57 PM
Mentor
jtbell's Avatar
P: 11,779
Quote Quote by olivermsun View Post
Exactly. The OP (manimaran1605) should compare equation (2.24) in Hecht with the other equations in that group on page 16, which are different ways of writing the same wave equation using different combinations of constants.
Register to reply
Related Discussions
Second Harmonic - Standing Waves Introductory Physics Homework 5
The combination of two harmonic waves with different frequency is no longer harmonic? Calculus 2
Two harmonic waves Introductory Physics Homework 5
Harmonic Waves help Introductory Physics Homework 2
Harmonic Waves Introductory Physics Homework 3
