Calculating Error for Measuring y3 in Range x1 to x2
  • Context: Undergrad
  • Thread starter Thread starter Doctor Luz
    Calculation Error
The discussion focuses on calculating the error for measuring a physical magnitude "I" within a specified range from x1 to x2, where y represents the value of I as a function of x. The continuous noise level is denoted as y1, which raises questions about its role in relation to I(x). It is clarified that y1 is not a direct error on I(x) but rather a noise affecting the measurement of x. The relationship between the errors in x and y depends on the specific function I, indicating that no universal formula exists for this calculation.
  • Understanding of function representation in mathematics
  • Knowledge of error analysis in measurements
  • Familiarity with noise in data measurement
  • Basic concepts of continuous functions
  • Research methods for calculating measurement error in physical sciences
  • Explore the impact of noise on data accuracy in experimental physics
  • Learn about specific functions and their derivatives in error propagation
  • Investigate statistical techniques for analyzing measurement uncertainty
Researchers, physicists, and engineers involved in experimental design and data analysis, particularly those dealing with measurement errors and noise in physical quantities.
Doctor Luz
Suppose I have some measures of certain physical magnitude "I" between the range x=x1 and x=x2.
I have for each x in this range a value y of I, then y=I(x)
I have a continuous level of noise y=y1.
I have I(x3)=y3 with x1<=x3<=x2.
how can I compute the error measuring y3?
Thank you
Mathematics news on Phys.org
If I read this correctly then I(x) is a function of x for x between
x1 and x2. You then say "I have a continuous level of noise y=y1."
That's a bit confusing. Is y1 a constant? Since you had already used y to represent the value of the function I(x), do you intend y1 to be a noise on the value of I(x) or on x itself? I doubt that you intend the former since that in that case the answer would be, of course, y1. If you intend the latter, then, since relationship between the error in x and the error in y= I(x) depends heavily upon the function I, there is no general formula.
  • · Replies 17 ·
