Register to reply
How was the core temperature of sun estimated ?
by Murtuza Tipu
Tags: core, estimated, temperature
Share this thread:
Murtuza Tipu
#1
Jul20-14, 12:44 PM
P: 35
It was estimated that the heat inside the core of the Sun inside around 15 000 000 C - this value is extremely enormous. How did scientists estimate this value?
Phys.Org News Partner Astronomy news on Phys.org
Smallest known galaxy with a supermassive black hole found
Mystery of rare five-hour space explosion explained
Glowing galaxies in telescopic timelapse
mfb
#2
Jul20-14, 12:51 PM
Mentor
P: 12,081
In general: you make models of the sun, and then you see which one agrees with all observations, and check which temperature this model predicts for the core.
A very simple model that gives a good approximation: fusion happens within a small volume in the core, and a part of the released energy is transported to the surface afterwards until it can escape as light. We know how much light the sun emits, and you can calculate the necessary temperature and density gradients inside that is required to transport this power and to keep the sun stable. Work from the surface inwards and you get an estimate for the core temperature.
Another nice approach is the fusion rate - this is known from the total power as well, and it can be compared to the fusion rate the sun would have at different temperatures.
Helios
#3
Jul21-14, 04:58 PM
P: 149
It is not necessary to know anything about fusion to estimate the Sun's central temperature. Very good estimates were made even before fusion was ever understood. After all, the Sun is just a self-gravitating ball of gas. It's Newton's gravity and the ideal gas equation. Find the central pressure and density and the temperature is found by the IGE.
Register to reply
Related Discussions
When is a magnetic core considered saturated ? At 50% of core - 100%? Materials & Chemical Engineering 2
Relationship Between Surface and Core Temperature of Steel Materials & Chemical Engineering 6
Estimated terminal velocity significantly less than estimated impact velocity Introductory Physics Homework 6
Magnetic Field Outside of Finite Solenoid Greater for Air-Core or Ferrite-Core? General Physics 6
Core temperature of stars Astronomy & Astrophysics 1
