Big vs Small Ice Cubes: Does Size Matter?
  • Thread starter Thread starter Pengwuino
    Ice
The discussion revolves around the effects of ice cube size on the melting rate and subsequent dilution of beverages, specifically sodas. Participants explore the implications of using small versus large ice cubes in terms of cooling efficiency and dilution over time.
  • Exploratory, Technical explanation, Debate/contested, Experimental/applied
  • One participant expresses a concern that smaller ice pieces may melt faster and dilute soda more quickly than larger ice cubes.
  • Another participant agrees, suggesting that increased surface area of smaller ice leads to faster melting when in contact with a warmer drink.
  • A third participant supports this view, providing an analogy to radiators and air conditioners to explain how surface area affects heat dissipation, while noting that crushed ice cools drinks more quickly.
  • A later reply encourages experimentation to test the claims made about ice size and melting rates.
Participants generally agree that smaller ice cubes melt faster due to increased surface area, but the discussion includes varying perspectives on the implications of this for drink dilution and cooling efficiency.
The discussion assumes equal conditions for the experiments proposed, such as the same volume of ice and soda, temperature, and type of glass, but does not detail how these factors might influence outcomes.
Individuals interested in beverage preparation, culinary science, or those curious about the physical properties of ice and its effects on drinks.
Pengwuino
Ok I've always had this weird feeling/fear that if i use like, the chopped off parts of ice cubes (the small parts you get when you 'crack open' a tray of ice cubes) in my cup for sodas... that the ice will melt quicker and dilute my soda quicker then if i used the big nice ice cubes that come out of the trays... is there any legitamacy with my fear :D
Chemistry news on Phys.org
I'd say Yeah. If you have the same volume of ice, but a bigger surface area exposed to the warmer drink, it will melt faster. Why don't you try it out with 2 glasses of water, a whole ice cube and a broken up one?
Yeah, this is definitely true. Everything else being equal (amount of soda&ice, temp of soda, same type of glass, etc) the crushed ice will melt faster. Look at a radiator in a car or an air conditioner. The reason it has all the fins is to maximize the surface area for heat to dissipate from. On the positive side, crushed ice will cool the drink more quickly than cubed ice. Also, both drinks will both reach the same equillibrium condition (i.e. watered down), but it's just a matter of how long.
Excellent suggestion mattyaouw. Let's get out there and experiment!
(BTW, I agree with matthyaouw & Grogs.)
  • · Replies 19 ·
11K
23K
  • · Replies 31 ·
9K
