Register to reply
Angular acceleration and centri fugal/petal Force...
by PhysicsStudnt
Tags: acceleration, angular, centri, force, fugal or petal
Share this thread:
PhysicsStudnt
#1
Jul24-14, 06:11 PM
P: 18
Experts,
I need to find out the centrifugal acceleration on a ball of mass m placed at a distance R from one end of the rod, and that end is being pivoted to rotate the rod..Of angular acceleration is alpha, is it correct to say,
Centripetal / centrifugal (in case that the ball remains stationary at the point) = R* (alpha) * M
On calculating the tangential force on the ball, i see a result, F(tangential) = M * R *(alpha)
I strongly feel that, the tangential force that we obtain on viewing the system from an external stationary reference frame, should be exactly same as the centrifugal force when we view it being in the rotating frame. Since i feel that both of the tangential force and the centrifugal force create the same influence but in different frames...
I need a more authentic explanation to it...could someone please explain...
Phys.Org News Partner Physics news on Phys.org
'Squid skin' metamaterials project yields vivid color display
Team finds elusive quantum transformations near absolute zero
Scientists control surface tension to manipulate liquid metals (w/ Video)
NascentOxygen
#2
Jul25-14, 05:15 AM
HW Helper
Thanks
P: 5,473
You wrote "angular acceleration is alpha". Do you mean angular velocity?
A.T.
#3
Jul25-14, 08:02 AM
P: 4,207
The inertial effects of angular acceleration of the reference frame are called Euler force, which adds to the effects of the angular velocity of the reference frame (centrifugal, Coriolis):
http://en.wikipedia.org/wiki/Euler_force
Quote Quote by PhysicsStudnt
If the system has angular acceleration in an inertial frame, then there must a real tangential force that exists in every frame. In the angularly accelerating restframe of the system this real tangential force is balanced by the Euler force.
Register to reply
Related Discussions
Angular Acceleration and Force Introductory Physics Homework 9
Angular acceleration given force, moment arm and inertia? Introductory Physics Homework 3
Find the Angular Acceleration, acceleration and friction force extered Introductory Physics Homework 1
Angular acceleration and force with constant angular velocity? Introductory Physics Homework 6
Centri... force with Fg Introductory Physics Homework 5
