Register to reply
Battery capacity loss
by Alex Jong
Tags: battery, capacity, loss
Share this thread:
Alex Jong
#1
Jul27-14, 09:52 AM
P: 6
Hello i have a noobquestion: does a polymer ion battery lose capacity faster when charged and discharged at the same time??
Phys.Org News Partner Physics news on Phys.org
New complex oxides could advance memory devices
Nature's designs inspire research into new light-based technologies
UCI team is first to capture motion of single molecule in real time
TESL@
#2
Jul27-14, 10:21 AM
P: 11
Yes, they are designed to be discharged and charged consecutively.
Alex Jong
#3
Jul27-14, 12:08 PM
P: 6
Quote Quote by TESL@ View Post
However, there are some products that do this.
CWatters
#4
Jul27-14, 02:38 PM
P: 3,264
How is it possible to charge and discharge a battery at the same time? Current is either entering or leaving the battery (or neither).
TESL@
#5
Jul27-14, 02:39 PM
P: 11
Current flows through the cells.
CWatters
#6
Jul28-14, 01:13 PM
P: 3,264
It's the direction of the current that determines if a cell is being charged or discharged.
If current is flowing out of the +ve and into the -ve it's being discharged. If it's into the +ve and out of the -ve it's being charged.
In both cases current is flowing "through the cells" so I don't follow your answer.
enorbet
#7
Jul28-14, 01:22 PM
enorbet's Avatar
P: 190
Quote Quote by CWatters View Post
I suspect he means rapid alternations between discharge and charging as in some electronic equipment that has batteries but also operates from a plug-in power supply like a common "wall wart".
It may also be reference to the nature of some batteries to act as if they have a memory of Charged and Discharged states. With some batteries, at the very least in the beginning of service, they should be fully discharged before they are fully charged or a loss in capacity occurs.
CWatters
#8
Jul28-14, 02:03 PM
P: 3,264
I agree that's probably what the OP meant.
I guess there are two strategies that could be compared...
1) Fully charging and then "fully" discharging
2) Partial charging and partial discharging
As I understand it the life of Li-Poly depends on the depth of discharge so I would expect option 2) to be slightly better.
See Table 2: "Cycle life as a function of depth of discharge"
http://batteryuniversity.com/learn/a...ased_batteries
Compare 100% DOD with 50% DOD. Sure in the case of 50% DOD each cycle only delivers half of the cell capacity per cycle but you get more than double the number of cycles (1200-1500) compared to a 100% DOD (300-500).
If you take that further and only use a 25% DOD each cycle delivers only a quarter of the capacity but the number of cycles is more than 4 times (2000-2500).
So it looks like keeping it topped up and doing only shallow discharge cycles is the way to go. However I think it's more complicated than that. For example other data on that pages suggests disconnecting the charger before the battery is fully charged might extend the number of cycles the battery can perform.
Some chargers are also more powerful than others. One I have that can deliver 2A. That might be enough to charge and power the phone so it's not clear that using the phone while on charge involves any discharging of the battery. The original charger was only 500mA and it's possible the battery might switch from charging to discharging and back again depending on what application I was running.
Register to reply
Related Discussions
Lithium battery capacity meter Electrical Engineering 20
Sizing of Battery-Capacitor capacity Electrical Engineering 0
HOw to calculate the number of electrons from a given battery capacity Introductory Physics Homework 1
Capacity of a battery General Engineering 6
Battery capacity and time to full discharge Introductory Physics Homework 1
