How Do Gradients, Rates, and the Term 'Per' Relate to Division and Ratios?
In summary, the use of "per" in 3 miles per hour indicates division, as it represents the rate of an object's movement in miles for each hour. Similarly, gradients and rates are expressed as ratios, as they compare the change in one quantity to the change in another quantity. This allows for a more accurate comparison, as it takes into account different sizes and scales.
Miraj Kayastha
80
Why does "per" in 3 miles per hour mean division?
Why are gradients and rates a ratio?
The meaning of "per" is "for each" .
Now read 3 miles "for each" hour.
And you divide the 3 miles by one hour you will get the speed of an object.
Are you not familiar with the basic equation
y = mx + b
where m is the slope, or rate ( and b is the intercept )
m is the ratio of the ordinate to the abscissa for any point on the line (x,y)
If you plot y-axis as the "miles" and x-axis as the time of hours , then the slope naturally follows as miles/hour, or in English terms miles per hour.
Same thing for gradient - for a surface that has a slope, its elevation will increase y-amount for every x-amount distance.
Two "similar triangles" have the same angles but can be different sizes.
In each case
Tan{Θ} = Length of opposite side/length of adjacent side
So if interested in the angle or gradiant it makes sense to compare the ratio of the sides rather than their absolute magnitude.
Gradient refers to the change in a quantity over a specific distance or interval. It is often represented by the symbol ∇ and can be calculated by dividing the change in the quantity by the corresponding distance or interval. This is similar to the concept of rate, which also measures the change in a quantity over time. Both gradient and rate are expressed as ratios, where the numerator represents the change in the quantity and the denominator represents the corresponding distance or time interval.
The term "per" in 3 miles per hour indicates a division because it is used to express a ratio of two quantities. In this case, it represents the ratio of distance (miles) to time (hours). The word "per" is derived from the Latin word "per" which means "by" or "through". In this context, it signifies that the quantity (miles) is being divided by the unit of time (hours).
Gradients and rates are both ratios because they compare two different quantities and express their relationship in terms of division. This allows us to measure and compare the change in a quantity over a specific distance or time interval, providing valuable information in many scientific fields such as mathematics, physics, and biology.
What is a gradient?
A gradient is a measure of the steepness or rate of change of a function at a particular point. It is also known as the slope or derivative of a function.
How is gradient calculated?
The gradient is calculated by finding the change in the y-value divided by the change in the x-value between any two points on the function.
What is a rate?
A rate is a measure of how one quantity changes in relation to another quantity. It is often expressed as a ratio of two quantities with different units.
What is the difference between average and instantaneous rates?
An average rate is the overall rate of change over a given interval, while an instantaneous rate is the rate of change at a specific point in time or position.
How are ratios and rates related?
Ratios and rates are related as they both involve comparing two quantities. A ratio is a comparison of two quantities of the same units, while a rate is a comparison of two quantities with different units.
  • Materials and Chemical Engineering
  • General Math
  • Other Physics Topics
