Register to reply
Linear motor with permanent magnets. Where is the sticky point?
by sv3ora
Tags: linear, magnets, motor, permanent, sticky
Share this thread:
sv3ora
#1
Aug2-14, 09:23 AM
P: 16
Hello, recently I have found this diagram http://www.cropcircleconnector.com/images/part4-12.jpg
Also seen some videos on youtube.
If this really work in moving a magnet linearly, the first thing that someone may think is why not to combine this linear motor into a circle, to move a magnet continuously?
Where is the sticky point that prevents from doing so?
Phys.Org News Partner Engineering news on Phys.org
'Smart material' chin strap harvests energy from chewing
Lockheed Martin advances live, virtual, constructive training in flight test
Lockheed Martin conducts flight tests of aircraft laser turret for DARPA
mfb
#2
Aug2-14, 07:13 PM
Mentor
P: 12,053
To get a force on a magnet, you need an inhomogeneous magnetic field. Making a long, homogeneous field is pointless. A magnet (or anything ferromagnetic) will accelerate until it reaches the homogeneous region of maximum field strength, and everything beyond that is pointless.
litup
#3
Aug8-14, 04:10 AM
P: 143
Quote Quote by sv3ora View Post
That device could give a one time shove on a magnet and so forth but you couldn't do continuous work with it, it needs switchable magnetic fields for that. The fields inside a 3 phase motor, for instance, is basically rotating around inside the stators which is why the motor can spin in the first place. It is MOVING magnetic fields that do work, not static fields. Just like static electricity, a voltage builds up if you rub a glass rod against a cat and you get a single spark. But the energy from that comes from the fact you moved the glass rod against the cat or fur piece or clothing, whatever, YOU are supplying the energy for that spark. The spark is gone, no more electrical work possible.
Think of a surfer on the beach. The surfer moves through the water because of the moving wave. When the wave stops, the surfer stops, it's as simple as that. There has to be a moving magnetic wave to do work otherwise those fields are just like a smooth ocean, you get no free lunch there, if you want to move, you paddle your butt around on the surfboard, the ocean will do nothing to help you move till the next wave comes by.
Register to reply
Related Discussions
Linear permanent magnet motor design Electrical Engineering 1
Strong motor using permanent magnets? Electrical Engineering 9
Defining dimensions of a linear eddy current brakes permanent magnets Classical Physics 2
Re: Permanent Magnets General Physics 4
Permanent Magnets Classical Physics 3
