Why are the electronic configurations of Copper and Chromium exceptional?
In summary, the electronic configurations of Chromium and Copper are exceptional because they have half filled and completely filled subshells, respectively. These configurations have extra stability due to greater exchange energy and symmetry.
kay
60
Why are the electronic configurations of Copper and Chromium exceptional? What is so different about them?
Chemistry news on Phys.org
Depends what you mean by "exceptional".
Do you know what the electronic configurations are?
How do they compare to other elements (i.e. in the same group)?
Do copper and chromium have some special properties?
They say that ' One might be puzzled by the fact that chromium and copper have 5 and 10 electrons in 3d orbitals rather than 4 and 9 as their position would have indicated with two electrons in the 4s orbital.'
Then they talked about the reason being half filled and completely filled subshells, which i could not understand at all.
Who is "they"?
The authors to my book. :P
And who are these mysterious "authors to my book"? Which book? Is it a secret?
It sounds like "they" are telling you the rules for populating electron orbitals in the "orbital model" for atomic structure. In order to help you I need to know more about what it is that you could not understand. From what you've told me, all I can do is advise that you read another book on the same subject.
Hi kay,
Half filled and full filled orbitals have extra stability due to greater exchange energy and symmetry.
Yes satvik i do know that. :/
But the thing is that i am not able to understand the fact that HOW are the elec configurations different/exceptional?
And how does the half filled or completely filled state of orbitals influence the elec configs (in the case of chromium and copper).
Tell me this.
Just by following the Aufbau principle you should have for the consecutive elements (each one having one electron more than the previous one):
d3s2
d4s2
d5s2
d6s2
However, total energy is that of dn plus that of sm. Energy of d5 is lower than the energy of d4 by enough to make d5s1 preferred over d4s2. So, instead of following the Aufbau principle "blindly" ground states of the consecutive elements go like
d3s2
d5s1
d5s2
d6s2
Actually from what I have read the common explanation about extra stability of half filled orbitals is not entirely true, but it is used in almost every book I can think of.
Tell me this.
According to Aufbau principal the outer most electronic configuration of Cr is 3d[itex]^{4}[/itex]4s[itex]^{2}[/itex] but due to extra stability of half filled orbital the electronic configuration of Cr is 3d[itex]^{5}[/itex]4s[itex]^{1}[/itex] as d[itex]^{5}[/itex]configuration is more symmetrical than that of d[itex]^{4}[/itex] configuration and greater no of exchange is also possible in case of d[itex]^{5}[/itex] that is 10 where as in case of d[itex]^{4}[/itex] no of possible exchange is 6 hence the exchange energy is less. Therefore the ground state electronic configuration of Cr is 3d[itex]^{5}[/itex]4s[itex]^{1}[/itex]. it is just a qualitative explanation.
What is an electronic configuration?
An electronic configuration is a representation of the arrangement of electrons around the nucleus of an atom. It describes the energy levels and sublevels of the electrons in an atom.
How is an electronic configuration determined?
An electronic configuration is determined by the number of electrons in an atom and the rules of electron placement, which include the Aufbau principle, Hund's rule, and the Pauli exclusion principle.
What is the significance of electronic configurations?
Electronic configurations are important because they help predict the chemical and physical properties of elements. They also provide a way to understand the reactivity and bonding of atoms.
Can the electronic configuration of an element change?
Yes, the electronic configuration of an element can change through processes such as ionization, where electrons are added or removed, or through chemical reactions where atoms gain or lose electrons.
Why do some elements have half-filled or completely filled sublevels in their electronic configurations?
Elements with half-filled or completely filled sublevels have more stable electronic configurations, following the rules of Hund's rule and the Aufbau principle. This stability is due to the balance of repulsion and attraction between the electrons in the sublevels.
  • Chemistry
  • Chemistry
