CRC Standard Mathematical Tables and Formulae, 30th Edition
The discussion revolves around the CRC Standard Mathematical Tables and Formulae, 30th Edition, focusing on recommendations for the text, its utility, and the knowledge required to effectively use it. Participants explore its role as a reference book rather than a textbook, and compare different editions.
  • Some participants recommend the book as very useful and comparable to other well-known references like Morse & Feshbach and Gradshteyn & Rytzhik.
  • There is a suggestion that a good knowledge of calculus is necessary to fully utilize the book, with one participant stating that about half of it requires calculus knowledge.
  • Another participant emphasizes that the book is a reference rather than a textbook, noting that it assumes a certain level of prior knowledge and lacks detailed explanations of tables and formulas.
  • Some participants express uncertainty about whether the 30th or 31st edition is better, with a general belief that the latest edition may correct errors from previous ones.
  • A participant mentions that earlier editions contained significant content related to logarithmic and trigonometric tables, which have since been reduced in newer editions.
Participants generally agree on the usefulness of the book as a reference, but there is disagreement regarding the necessity of calculus knowledge and the comparison between different editions. The discussion remains unresolved regarding which edition is superior.
Participants note that the book's content has evolved over time, particularly in relation to the inclusion of integral and differential tables, and that earlier editions may differ significantly in content from newer ones.
z-component
CRC Standard Mathematical Tables and Formulae (30th Edition)
by Daniel Zwillinger
Does anyone have any recommendations for this text?
Thank you. :smile:
Yes.Mighty good.I got the 31-st edition :-p
It's really worth it.I mean,it's in the same league with Morse & Feshbach and Gradshteyn & Rytzhik.
Daniel.
Yes recommend. Very useful.
Thanks for the recommendations. Some follow-up questions:
1) Is a good knowledge of calculus required to get the most out of this book, and if so, how much of it can be understood without calculus?
2) Which is better overall, edition 30 or 31?
I don't know for the second question...Usually the latest edition has the advantage that some errors (if they were) in the previous edition would have been corrected.
Nope,it's more than a reference with a great deal of numerical tables.But knowledge of calculus didn't hurt nobody ...:wink:
Daniel.
Sounds great! I am going to buy it. :approve:
Thanks. :smile:
About half of it requires knowledge of calculus.
First of all this would not be what I consider a "text book". It is a reference book, it contains a wealth of information but assumes a lot. A good portion of the book is devoted to the integral and differential tables, without knowledge of Calculus these are pretty much useless. But there is a lot useful information outside of those sections. HOWEVER, as I stated above, this is NOT a text, there is often little or no explaniation of the meaning of a table or formula, you are supposed to know. So if you do not have some level of knowledge of this is not a book to learn from. It is a great place to go if you need a quick referance, I use mine frequently.
What integral said. Everybody who's in and around science needs to have a copy of some edition, but I don't think it's urgent to have the latest edition.
BTW, Mine is a 27th edition. I have had it for nearly 20yrs. somewhere in the 70's there was a major change in the content of the Math Tables. Prior to calculators the main content, along with the differential and integral tables where tables of logs and the trig functions. These actually made up a significant portion of the book, since those tables have become unnecessary they have added more material to other sections. If you have 2 different editions available you may want to compare the table of contents to see if they have different sections. Choose the one which most meets your needs. I doubt that there will be much difference.
