Register to reply
Gears' inertial response
by TechFan
Tags: gears, inertial
Share this thread:
TechFan
#1
Aug5-14, 01:11 PM
P: 34
Hi:
I'm building a computer simulation for a 3 gear train system. So far the gears rotate with mouse movement horizontally. Now I'm adding a fictitious motor and braking system to start/stop rotation with mouse clicks. I multiplied the rotation angle by [1-e(-t/TC)] to simulate exponential acceleration and e(-t/TC) for braking for exponential deceleration. Is exponential is the right way to do it? or is there any other better equation. This is just a simple case with no other external conditions influencing; but just the system inertia.
In general terms this is the equation I'm using.
Acceleration=[1-e(-t/TC)];// acceleration case
Acceleration=[e(-t/TC)];// braking case
Thanks
Phys.Org News Partner Engineering news on Phys.org
'Smart material' chin strap harvests energy from chewing
Lockheed Martin advances live, virtual, constructive training in flight test
Lockheed Martin conducts flight tests of aircraft laser turret for DARPA
Baluncore
#2
Aug6-14, 03:10 AM
Sci Advisor
Thanks
P: 1,955
The meshed gears will have kinetic energy proportional to RPM squared.
The motor will provide that energy. You must specify the Torque to RPM curve for the motor.
Power = torque * RPM = watts = joules of energy per second.
Use that to compute the change in velocity over time as energy flows in or out.
There will be some energy losses that will remove energy and so reduce the RPM. Ignore them for now, or make them proportional to RPM.
TechFan
#3
Aug6-14, 04:04 AM
P: 34
Hi:
Interesting info. I'll experiment trying to code that somehow (????) and see the results. My goal is just having an acceptable "visual effect", although using the real equation will be much better.
The real question would be: What is the equation for the change in rpm with time (angular acceleration)? I assumed it to be exponential so it will tend to the end value asymptotically with time in both cases.
Thanks
Baluncore
#4
Aug6-14, 05:57 AM
Sci Advisor
Thanks
P: 1,955
Incredible gear art.
http://www.bugman123.com/Gears/index.html
TechFan
#5
Aug6-14, 06:23 AM
P: 34
Wow that is awesome!. Thanks.
Register to reply
Related Discussions
Forces gears cause to the shaft (spur gears) - force diagram Engineering, Comp Sci, & Technology Homework 1
Freely Falling Inertial As Seen By Distant Inertial Observer Special & General Relativity 4
Dynamic response of a pair of gears in ansys Mechanical Engineering 0
Derivation of non-inertial terms in non-inertial systems using rotation matrices Advanced Physics Homework 0
Is centripetal force present in inertial and non-inertial frames? General Physics 1
