Determining a formula of a hydrate
  • Thread starter Thread starter ~angel~
    Formula
The discussion revolves around determining the formula of a hydrate of barium hydroxide through a titration process. Participants are analyzing a specific mass of the compound dissolved in water and the resulting titration with hydrochloric acid.
  • Participants discuss the need to balance a chemical equation for the reaction between barium hydroxide and hydrochloric acid. There are attempts to identify the correct stoichiometry and to calculate moles involved in the titration process.
Some participants have provided insights on how to approach the problem, such as calculating moles of the acid and base involved. Others express uncertainty about balancing the equation and determining the formula of the hydrate from the data available.
There are mentions of specific measurements and conditions, such as the concentration of hydrochloric acid and the volumes used in the titration. Participants are also grappling with the implications of charge balance in the compounds involved.
~angel~
Barium hydroxide froms several hydrates. A specimen of barium hydroxide, suspected of being a hydrate, was prepared and analysed as follows to determine its formula.
3.632 g of the compound was dissolved in water to give 250.0mL of solution. 25.00 mL of this solution was titrated with 0.0987 M of HCl, using methyl-orange as indicator. Precise titrations of 23.34, 23.26 and 23.29 mL of HCl were obtained. Determine the formula of the hydrate.
I tried writing a balanced equation for the reaction, but I can't seem to balance it.
Also, I'm not exactly sure how to approach this problem so any help would be greatly appreciated.
Thanks.
Thanks.
A good start to most titration questions is to find the number of moles of the known acid/base that was used and then find the number of moles used for the acid. Then find how many moles there are in the solution of the acid/base that you are trying to work out.
The Bob (2004 ©)
I know what you mean but I can't seem to balance the equation.
I thought it was BaOH + HCl --> BaCl2 + H2O
If that is right, how do you balance is because it seems to be one of those equations where no matter what number you put in front, it is different on the other side.
Thanks
Barium has 2+ for its charge. Hydroxide is a -1 ion.
Well that's explains it. Thanks.
I haven't really encountered a problem like this before. I have found the number of moles for each substance. Ba(OH)2 has 1/2 the moles of HCl. Is this for 25.0mL?
How exactly can I determine the formula from what I've got?
Thanks.
I'm not sure if this will be of specific help here, but still:
In titrations, a more fundamental quantity is gram equivalents (or milliequivalents). If A and B are titrated with each other, then gram equivalents of A = gram equivalents of B. To convert from moles to gram equivalents and vice versa, you need to multiply and divide by a factor. As you can see using simple examples, moles of A and B are not necessarily equal in titrations and there's usually a factor involved.
40K
109K
