How Do I Properly Convert a Triple Integral to Cylindrical Coordinates?
To convert a triple integral to cylindrical coordinates, follow a systematic approach: identify the limits of integration in Cartesian coordinates, convert to cylindrical coordinates using x = ρ cos(φ), y = ρ sin(φ), and z = z, and substitute these limits into the integral. The correct integral for the volume enclosed by the surfaces x² + y² + z² = 2 and z = x² + y² is V = ∫₀²π ∫₀√2 ∫₀ρ² ρ dz dρ dφ. The evaluation of this integral yields (π/3)(4√2 - 6), which may differ from expected results due to potential evaluation errors or misinterpretations of the problem.
  • Understanding of triple integrals in calculus
  • Familiarity with cylindrical coordinates
  • Proficiency in LaTeX for mathematical notation
  • Experience with integral evaluation techniques
  • Study the conversion process from Cartesian to cylindrical coordinates in detail
  • Practice evaluating triple integrals using software like Mathematica
  • Learn about the geometric interpretation of integrals in cylindrical coordinates
  • Explore common pitfalls in integral evaluation and how to avoid them
Students and professionals in mathematics, physics, and engineering who are working with multivariable calculus and need to understand the conversion of integrals to cylindrical coordinates.
MaximumTaco
Firstly, can someone please demonstrate the proper Latex code for the terminals on a multiple integral? Thanks!
Anyway, as you can probably see, I'm calculating the volume enclosed by x^2+y^2+z^2 = 2 and z = x^2+y^2 using a change to cylindrical coordinates.
[tex] <br /> V = \iiint_{0}^{2\pi}_{0}^{\sqrt{2}}_{\rho^2}^{\sqrt{2-\rho^2}} \rho dz\,d\rho\,d\phi<br /> [/tex]
Is that integral right?
The answer i get when evaluating the integral is (pi/3)(4sqrt(2) - 6), which is the same doing it by hand or using Mathematica. But it doesn't agree with the expected answer.
[tex]V=\int_{0}^{1}\rho \ d\rho \int_{0}^{2\pi} d\varphi \int_{0}^{\rho^{2}} dz[/tex]
Daniel.
To properly convert a triple integral to cylindrical coordinates, follow these steps:
1. Identify the limits of integration for each variable in the Cartesian coordinates. In this case, the limits are x = 0 to x = sqrt(2), y = 0 to y = sqrt(2), and z = 0 to z = x^2 + y^2.
2. Convert the Cartesian coordinates to cylindrical coordinates using the equations x = \rho \cos{\phi}, y = \rho \sin{\phi}, and z = z.
3. Substitute the converted limits into the integral. The integral should now be in terms of \rho, \phi, and z.
4. Change the order of integration if necessary. In this case, since the limits for z depend on \rho and \phi, it is best to integrate with respect to z first.
5. Evaluate the integral by integrating with respect to z, then \rho, and finally \phi.
The integral you have written in LaTeX looks correct. However, the answer you obtained may not be the expected answer due to errors in the evaluation or a typo in the original problem. It is always a good idea to double check your work and use a calculator or computer program to verify your answer.
