Calculating Moment of Inertia of Modified Disk
The discussion revolves around calculating the moment of inertia of a modified circular disk, which has a hole cut out from it. The original poster describes the dimensions and mass of the disk and the hole, and seeks to determine the moment of inertia about the origin.
  • The original poster attempts to find the moment of inertia by calculating the inertia of the whole disk and subtracting the inertia of the hole. Some participants question whether the moment of inertia of the hole was calculated with respect to the center of the disk. Others suggest using the parallel axis theorem and discuss methods for finding the mass of the cutout part.
The discussion is ongoing, with participants exploring different methods to approach the problem. Some guidance has been offered regarding the use of the parallel axis theorem and the concept of superposition in calculating the moment of inertia. However, there is no explicit consensus on the preferred method or the validity of certain approaches.
Participants express differing opinions on the use of negative mass in calculations and the implications of various methods on the understanding of physics principles. There are also discussions about the assumptions made regarding the uniformity of the disk and the calculations involved in determining the mass of the cutout part.
choole
A uniform circular disk has radius 35 cm and mass 350 g and its center is at the origin. Then a circular hole of radius 11.667 cm is cut out of it. The center of the hole is a distance 17.5005 cm from the center of the disk. Find the moment of inertia of the modified disk about the origin.
First i find the moment of inertia of the whole disk and then i find the inertia of of the hole .
Then i subtract circular hole disk form the uniform circular disk inertia
but i am not getting right answer
Did you find the MI of the hole with respect to the center of the disk ?
no i didn't how do we do that
Look up the "parallel axis theorem"
but how do we find the mass of the cutout part.
Is this correct
350/(35)^2 * area of the cutout part
What is the mass of the whole disk ? What is the area of the whole disk ? What is the area of the cut-out part ?
Ok divide this problem into two parts .
First find the moment of inertia of complete disc (without any part cut) about the origin.
Now find MI of the cut out part about the origin using parallel axis theorem.
For the second part , you will have to find out mass of cutout part,this can be easily done as the disc is uniform , use unitary method.
Now add the MI of both parts , remembering that the mass of the cutout part that you calculate has to be taken negative.
Call me an old fashioned person, but I just don't like "negative mass"--its like one of those tricks invented by non-theorists who wanted to finish problems (sorry if I sound offensive but its kinda true isn't it!). Instead it is easier to regard the new arrangement as a SUPERPOSITION of the cut mass and the mass without the cut portion. Their sum must equal the original MI. Remember to use the same axis for reference.
So this really is an application of one of the most fundamental ideas in physics: Superposition. I like to keep it that way. Negative mass, "pseudo forces" and some other things should be kept away and used only when needed (lets use pure unadelterated physics please!).
Actually the negative mass method is the same as the superposition principle.
In superposition method , we first calculate MI due to uncut par and then we subtract the MI due to cut part . And by taking negative mass, we need not subtract the two MI's.These are two different ways of saying the sane thing and do not adulterate physics!
Dr. Brain if you've been studying in some coaching school, then you will be expected to know some of these tricks but when you get into mainstream physics (if at all that's your pursuit) you will discover the fallacies in some of these tricks. It is very easy to point similarities between two methods one of which seems clever and useful but is deceptive, but it isn't as easy to figure out the intricacies of physics by using tricks instead of resorting to hardcore time-tested principles.
I do not think it appropriate therefore, to argue with you about pure physics and the adulterated version you are trying to justify, as this would be a waste of time and would stray us away far into the shallowness of argument :-D. Anyway, I am only against the mechanization of such "tricks" replacing PHYSICS.
Cheers
Not extending the argue further, I agree with you fully...But there's no harm using the tricks as per me..
  • · Replies 28 ·
  • · Replies 19 ·
15K
  • · Replies 40 ·
