Register to reply
Chiral gauge theory and C-symmetry
by mkgsec
Tags: chiral, csymmetry, gauge, theory
Share this thread:
mkgsec
#1
Aug19-14, 03:19 AM
P: 4
Hi, I have a question in Srednicki's QFT textbook.
In p.460 section 75(about Chiral gauge theory), it says
"In spinor electrodynamics, the fact that the vector potential is odd under charge conjugation implies that the sum of these diagrams(exact 3photon vertex at one-loop) must vanish."
That's good, because it's just the Furry's theorem for odd number of external photons. But I find the subsequent statement confusing.
"For the present case of a single Weyl field(coupled to U(1) field), there is no charge conjugation symmetry, and so we must evaluate these diagrams."
But shouldn't the transformation rule of [itex]A^\mu (x)[/itex] under C,P or T be universal regardless of specific theory?
Phys.Org News Partner Physics news on Phys.org
How did evolution optimize circadian clocks?
New webcast series brings cutting-edge physics talks to the world
High Flux Isotope Reactor named Nuclear Historic Landmark
The_Duck
#2
Aug19-14, 10:49 AM
P: 874
In spinor electrodynamics, the Lagrangian is *invariant* under the C operation, which among other things takes ##A \to -A##. One consequence of this is that there should be an equality between the following three-point functions:
##\langle A(x) A(y) A(z) \rangle = \langle(-A(x))(-A(y))(-A(z))\rangle = -\langle A(x) A(y) A(z) \rangle##
The only way this equality can be satisfied is if ##\langle A(x) A(y) A(z) \rangle## vanishes. This is Furry's theorem. This result relies crucially on the fact that the C operation, under which ##A \to -A## and also ##\psi## transforms nontrivially, is a *symmetry of the Lagrangian*. That's why we have the equality above.
In the chiral case, you can still define a transformation under which ##A \to -A## but it is no longer a symmetry of the Lagrangian, no matter what transformation rule you choose for ##\psi##. Therefore you cannot make the same argument and Furry's theorem does not go through.
mkgsec
#3
Aug19-14, 12:40 PM
P: 4
But doesn't Furry's theorem still hold even if the langrangian has no C-symmetry? I thought it is valid as long as the vacuum is invariant under C. What am I missing here?
The_Duck
#4
Aug19-14, 12:45 PM
P: 874
Why do you think the vacuum is invariant under C?
mkgsec
#5
Aug19-14, 12:49 PM
P: 4
Well... Maybe because the vacuum contains no particle? Are the invariance of the vacuum and invariance of lagrangian related to each other?
The_Duck
#6
Aug19-14, 01:01 PM
P: 874
Quote Quote by mkgsec View Post
Right. If your theory has a symmetry and you have a unique vacuum state, then the vacuum is invariant under that symmetry. If you have some operation that is not a symmetry of your theory, there's no reason to expect the vacuum to be invariant under that symmetry.
mkgsec
#7
Aug19-14, 01:08 PM
P: 4
It's very clear now! I always assumed that the vacuum is invariant under any operation. Thank you, it was very helpful :)
Register to reply
Related Discussions
[Holography] Global symmetry in boundary corresponds to gauge symmetry in bulk? Beyond the Standard Model 14
Why are there several gauge fixing choice for gauge symmetry fields? Quantum Physics 3
γ5 and chiral symmetry High Energy, Nuclear, Particle Physics 1
Chiral symmetry breaking and approximate flavour symmetry High Energy, Nuclear, Particle Physics 8
Chiral symmetry in QCD Advanced Physics Homework 1
