Conversion of electromagnetic units
The discussion centers on the conversion of electromagnetic units, specifically the relationship between voltage, tesla, nanotesla, and frequency, particularly at 42.58 MHz. The user seeks to understand how 1 volt translates across different mediums, especially hydrogen, and how atomic scattering factors influence frequency attenuation and decibel loss. The calculations provided involve proton precision frequency calculations and emphasize the need for a predictable model for resistance and power loss across various elements. The complexity of the topic necessitates a solid grasp of physics and mathematics for accurate analysis.
  • Understanding of electromagnetic units and their conversions
  • Familiarity with proton precision frequency calculations
  • Knowledge of atomic scattering factors and their impact on frequency
  • Basic principles of decibel measurement and attenuation
  • Research Faraday's law and its application to electromagnetic unit conversions
  • Explore online calculators for frequency and decibel calculations
  • Study atomic scattering factors and their effects on different elements
  • Investigate the relationship between temperature coefficients and frequency stability
Physicists, electrical engineers, and researchers in electromagnetic theory who are focused on unit conversions and frequency analysis in various materials.
armored
I would like to ask a question that I am having a hard time finding the answer to.
This is my question:
1 volt per second equals 1 tesla per square meter equals 1000000000 nanotesla and yielding frequency of 42580000hz or 42.58mhz denotable through the proton precision frequency calculation which is: Capacitance to frequency "W.value =42.58*(this.value*1E-9)*1E6" "F.value = (1E9*(this.value*1E-6)) / 42.58" .
these calculations I need to know a few different variables for the how the 42.58mhz was 1 volt because they were using a medium of hydrogen, and all equations are thereby based off of efforts to describe a system through hydrogens atomic scattering factors, when there are billions of different frequencies, yielding billions of different elements, and anyone will yield a different resistance in power in decibels to the 42.58mhz, also a temperature coeffecients as not all elements are stable at the temperature that we are inside of now, and frequency db, or power is directly effected by temperature, and the power in db will drop off accordingly with the atomic scattering factors of each element and the temperature fluctuations, thereby yielding a non noted power level in decibels into the element is not really what I am in search of, I am looking for the power in db of the 42.58mhz into the hydrogen, the loss in db, and the output in db of the 42.58mhz. Today the element is denoted by it's characteristics on the atomic scattering factors to retain the frequency induced into it, thereby when a ping back is hit the note is taken for future analization of each element with the same characteristics. What I am essentially looking for is a process that is denotable with a predictable outcome for resistance and db loss from frequency attenuation through the elements, and I am not really sure how the proton precision frequency calculation applies to changing the amount of nanoteslas into a frequency, when inside it has 42.58mhz which is denotable through only one element with no power readings before and after. Thereby we have many elements around us so the notable differences would be seen in a computer model. The meters which are based on the galvanometer to test for the one volt on the medium of copper and adjust it accordingly to make 1 volt equal 1 volt by the equation which is frequency=1over capacitance of 1 times resistance of 1. This is a very unusual means of accurately seeing exactly what you have if you are basing the measurement off of one element. I am looking for a way to know exactly what 1 volt registers in every medium so that a accurate computer model can be made. What frequency is 1 volt, and the attenuation factor for each known element. Any help you can give me in advace would be greatly appreciated.
That's nonsense.Take Faraday's law and chew on the units of the quantities involved.
Daniel.
It seems like you are asking about the conversion of electromagnetic units and how they apply to different elements and their atomic scattering factors. This is a complex topic that requires a deep understanding of physics and mathematics. I would recommend consulting with a professional in the field or referring to reliable sources such as textbooks or scientific papers for accurate information. Additionally, there may be online calculators or tools available that can help with your specific calculations. Good luck in your research!
  • · Replies 44 ·
