Understanding Lights Wired in Series: Explaining Basic Electricity
  • Context: High School
  • Thread starter Thread starter senorbrown
    Lights Series
The discussion revolves around understanding the behavior of light bulbs wired in series within an electrical circuit, specifically focusing on the power readings observed when using a watt meter. Participants explore the implications of resistance and current in series circuits and seek to clarify the underlying principles of basic electricity.
  • Homework-related
  • One participant is constructing aids for a classroom demonstration and questions the observed wattage of three 25 watt bulbs in series with a supply voltage of 123 VAC, noting a reading of about 12 watts.
  • Several participants inquire about the measurement setup, asking where the wattage is measured in the circuit and whether the voltage is continuous or alternating current.
  • Another participant explains that if the resistance of the bulbs did not change with temperature, the total resistance in series would be three times that of one bulb, leading to a calculated power of 8 watts based on the formula P=V^2/R.
  • It is noted that the actual reading of 12 watts is greater than the calculated 8 watts, attributed to the bulbs remaining cool and having a smaller resistance than when hot.
  • One participant confirms that the bulbs in series take the same current, referencing the relationship between power, current, and resistance.
Participants express varying levels of understanding regarding the measurements and calculations involved, with some clarifying points while others present differing interpretations of the observed phenomena. The discussion does not reach a consensus on the implications of the measurements or the underlying principles.
There are assumptions regarding the behavior of the bulbs under different temperatures and the accuracy of the watt meter readings. The discussion also highlights the complexity of measuring power in series circuits, which may depend on specific conditions not fully explored.
Individuals interested in basic electricity concepts, particularly in educational settings, as well as those exploring series and parallel circuits in practical applications.
senorbrown
I need some help with a formula, I am constructing some aids for a class room demonstration on basic electricity. I am using lights to demonstrate series and parallel cicuits, also trying to explain some of the basic laws. My question, If I hook three 25 watt bulbs in series with a supply voltage of 123 VAC the displayed wattage (under power) is about 12 watts (I am using a meter). I would like to explain using an appropriate formula but I don't know how.
Science news on Phys.org
Where do you measure that Wattage...(in which point of the circuit)?VAC is that continuous or alternative current...?
Daniel.
I am using a watt meter that allows me to select either Volts, Amps, Watts, or KWHR. It is AC.
Hes asking between which nodes did you connect the multimeter
If the resistance did not change with temperature (But, it does.) due to the current through it, then the resistance of the three bulbs in series would be 3 times the resistance of one bulb. The power (given by P=V^2/R) would be
25/3=8 Watts. You read 12 Watts (>8), because there is 1/3 the current through each bulb. They stay cool and have a smaller resistance than a hot bulb.
The bulbs are in series, they all take the same current.
[tex]P_{res} = IV = \frac{V^2}{R} = I^2R[/tex]
Thank you, that is very clear
  • · Replies 52 ·
